project hardrock
project hardrock
85 daihastu rocky
solid front diff stiff as suspension, no ground clearance small feet. being turned into a mud eating monster.
waste of time modifying you may say? well its mine and i'll make it as big and as bad as i can afford to at the mo
list of mod's so far.
31" pirelli scorpions or 750 michallin X's depends on the day to what i'll use
hilux rear springs with 3 leaves removed all round
long shocks in the front
3'' longer shackles
flipped steering set up
custom $40 pvc snorkle
moved diffs
front forward 2-3"
back backwards 2-3"
attitude to boot
still to come
longer drive shafts
longer brake lines
cut gaurds
rear to be cut off and turned into a proper well deck
winch
roll cage
more attitude to boot
standard with longer shackles in place
new shackle
3'' longer shackles
moved diffs
front forward 2-3"
back backwards 2-3"
attitude to boot
still to come
longer drive shafts
longer brake lines
cut gaurds
winch
roll cage
new shackle
Sweet as, just thought to mention it. I know off road the longer shakles give a much smoother ride. Also saw an article on the outerlimits suzuki forum about moving the shackle hanger 50mm so the angle is more pronounced to give better downward travel. Seemed logical so maybe something I will try when all my plans come to fruition (the Missus weakens and says yes I can get a new truck).
I believe you move the shackle pivot point on the chassis closer to the fixed end of the spring but I would assume that the spring pack would have to be soft to get the maximum amount of flex.
The link to the zuk spring story is (stuff is part way down)
http://carl.outerlimits4x4.com/viewtopic.php?t=110437
check out their diahatsu area also
http://carl.outerlimits4x4.com/viewforum.php?f=18
Heath
Heath
looking good 2rocky thats some beast now
whats involved with the body lift? im looking at maybe a modest 1' one (mainly as they seem to sneek past the local wof shop without notice)
After the weekend performance i really need more ground clearance, I have a set of hilux springs coming from a club member but as Ive just been diagnosed with a hernia i cant fit them yet until I recover from the operation
at least I will be able to fit my winch this weekend should be here tomorrow or thursday... father-in-law has offered to do the lifting of the winch into place once i make up the mounts for it, I had a poke around under the front bumper and I think there is enough room to hide the winch behind it with having to modify it much
shame we live at the oposite ends of the country .. would be good to catch up and have a good look at ya beastie'(s)
the best and easist way to get more ground clearance is tweak the torsion bars and big feet,
as for the body lift there are 5 blocks a side its just a matter of pulling the old ones out and get some new ones. i used white nylon blocks for mine ya can see the front one in one of the pics but id recommend that you go to a wreakers and try and find larger rubber ones will kep the ride a litle soffter and vibration free
all done now just going through the process of finding the kinks and ironing them out
damage report to date is
one rear drive shaft and steering shaft rubber bush thing
still a few touch up not jobs to do like securing the rollbar properly putting a perspex window in the back etc
the final result looks like this
cameronmaxwell@xtra.co.nz
0274202727
0274202727
Thats a pretty sweet piece of hardware you're building there dude. Wish i could build up something like that, Just its a bit dodgy having a vehicle on a trailer in Porirua, The locals tend to borrow them....
Don't Drink And Four Wheel Drive, Those Broken Bottles Are A bitch To Clean Out Of Your Truck.
cheers for that mate just aframe it then or tie a dirty great big unhappy breed of dog to the draw bar that should stop the locals
0274202727
0274202727
cheers for that guys
still got a bit more flex left in it i think as that was done with only front wheel drive as im still waiting on the new drive shaft
0274202727
0274202727
Re: project hardrock
since last post ive done a little more to the beast, put the fuel tank on the deck, not ideal for center of gravity but needed to do it before the rear diff knocked a hole in it, have a winch for it now just have to get a drive cog for it ( anyone know of any their like rocking horse shit to find) longer shocks and beefed up front shock mounts n place. just have to reposition the mounts higher now as i dont have enough up travel and they bottom/top out
0274202727
0274202727
this build seems to keep on going,
now have the pto winch on it just need to pull it appart and cut the cradle down to reduce the dist it sticks out and build a new bullbar for it.
this coming year it is going to become coiled i think as well
0274202727
0274202727
looks like a good wee truck do you have soa looking at putting hilux diffs under mine and doing soa
nope its just the standard diffs with extended hangers and large body lift, im thinking i might change to safari diffs as i keep breaking cvs and axels and coil it at the same time
0274202727
0274202727
much work in doing it? have you looked into it? i should prob do something with mine cos if you break them with standard motor mine wont last long with v6 turning them. do you need any motor parts i got a good runner here 2.8 turbo
not too sure being that mines only a offroader i can do it how i like, but if your going to keep yours leaf sprung there is bugger all in doing it and you'd be better going to hilux or 80 series diffs as they are slightly narrower than the safari so cert wouldnt be as much of an issue,
could be interested in the whole motor at the right price
either that or just the turbo and intake manifold and oil lines for it
0274202727
0274202727
forgot to add my tyres are putting a lot of stress through the axles being 33x12.5 mongrels when they bite they often bite pretty hard, twisted a rear drive shaft up one time, the other problem i have is my drive shafts must have a lot of movement in them as they keept spiting the bolts out even if they are loctited in, might have to go to nylocs and see if that helps
0274202727
0274202727
make an offer on motor if you want if you in roxburgh i could meet you half way or right price i could bring it up
pm me bout it
pm me bout it
- Andrew1706
I used 60 series cruiser diffs in my Blizzard.
I moved the rear mounts on the chassis out by 70odd mm but the fronts are identical
http://www.offroadexpress.co.nz/gallery/fat-blizzard
Users browsing this forum: No registered users and 22 guests
