Goodride SL366 MT Tyres???
Anyone used the Goodride MT's before?
I can get some real cheap and was wondering what they were like.
Re: Goodride MT Tyres???
I am running the a/t version of those unbalanced on my ute without any shake and have got 6months of 100km a day use and still got 6mm tread.
I have a full set of the m/t's but haven't got a spare set of rims to put them on yet, looking at them i would say they will be soft so wouldn't use them on the road to much.
can you get them in 35s??
Not yet! They are hoping to get more sizes.
i have a set on my XJ they are a bit softer (side wall ) to my MTZ but over all no complaint . they do the job ,i have done 2000 km ....
had them on my old proceed grip well and grip well on road to was surprised and good price will be getting these or dynapro rt03s for my navara
- Driver/Navigator
nizute wrote:I am running the a/t version of those unbalanced on my ute without any shake and have got 6months of 100km a day use and still got 6mm tread.
What model A/Ts are you running?
My biggest fear is if I die my wife will sell my toys for what I told her they cost!
Old school wrote:nizute wrote:I am running the a/t version of those unbalanced on my ute without any shake and have got 6months of 100km a day use and still got 6mm tread.
Goodride SL369
Finally got round to putting some of these MT's on my Nissan.
Will be interesting seeing how they perform on-road as well as off.
Re: Goodride SL366 MT Tyres???
Well after giving them a run around on the tarmac/off road course here in CHCH, I found out they really needed balancing.
The old machine at work has a spaz with large wheels so I didn't bother to balance them when I fitted the tyres to the rims.
(Rims are 15x7 steels and the tyre size is 31x10.50R15)
Had to call in a favour from a supplier through work to do them for me. Made a huge difference. Needed between 70 - 130gms per wheel, so not too bad for MT's.
Noise on the road isn't bad. Certainly no worse than the 90% worn AT's that were on before anyway.
Intially had 40psi in them but the ride quality was harsh so I dropped them down to 35, and just that little bit made a noticable difference.
Road handling, so far in the dry, is good. I haven't noticed a difference in cornering ability, yet, but then I haven't been pushing them that hard.
I thing that I did notice straight away, was the speedo reads correctly now. Before with 30x9.50 tyres it was out by 7-8kph faster at 100kph. Now bang on, according to my Navman GPS anyway.
Next test is in a few days on a hunting mission. Looks like the weather is going to turn bad so they might get a work out. Can't wait
thanks for the info
cheers,
steve
cheers,
steve
Can you source them quiet cheap mudbugga
onebadman wrote:Can you source them quiet cheap mudbugga
Only cheap for myself sorry. I can't supply to others.
The deal I got was staff price only through work.
All good
They are cheap as chips on trademe.
After a weekend hunting on a high country station, the tyres worked well.
Had no issues what so ever. Even when the weather turned decidedly crap and the clay tracks turned slippery, they felt good.
Only drama was when a Falcon pulled out of a driveway without looking and we had to take assertive action which meant going through a very large puddle covering the entire opposite lane at open road speed. Got a bit twitchy but anything would've in that situation. The splash/wave completely covered the Falcon in shitty cow crap water. Real bugger the driver had his window right down and copped it eh.
Still really need to get them really muddy yet to see how they go, but so far so good.
Had a customer at work with these on his L200. He is happy with them and commented that they are wearing really well. They didn't look worn at all and have been on the ute for about a year. His only negative comment was they dig excessively in sand and he gets bogged.
Also they look to have a decent tread pattern and good tread depth, the rubber felt a bit hard so they may struggle on rocky terrain.
Any update on these? How do they perform in the mud?
Are the sidewalls soft - ie do they bag well?
Any more feed back on the goodride tyres and how they're performing and lasting?
Currently it gets interesting with the maxxis high way terrains, so was thinking a cheap set of mudgrips truck only gets used a couple weeks a year so hard to justify expensive tyres that might last a bit longer...
How have you got on with these tires? Looking at some here in Chch too and keen for some feedback on them
- Suza
Just got a set of these in 33" as they were on a really good trade special. Put them on Friday seemed to fit up ok the usual struggles when fitting a bigish tyre and its only 2 degrees not often I have to jump on tyres to get them to sit down far enough to get the top bead on, balanced up ok not big worries there. So far I have done a 1000km on them (shot down the coast on Friday afternoon and then back Saturday to look at some sections). No nosier than the RT03's they are replacing, a couple of we road handing quirks but nothing major.
Spent today cutting firewood for a contract and than seem to do the job in the mid they dig and clear so that's a good start, on the hard stuff I need to drop the pressure a bit as at 40psi they cant quite grip the frozen ground.
I will post again about them once I have driven them some more
For what u pay you really cant go wrong .
They are 159 each at tyres to go chch .
I got a half worn set free with truck . They did want 140grams to balance .
They did dig in on birdlings flat where a new hilux with road tyres didnt dig in . But it I did just keep driving
They drive round in the birdlings flat mud flats pretty good
- Suza
So I have run these for about 7000km now and they are great. Did my first coast trip on them this weekend and I love them. Dropped them to 25lb and they just kept on performing, wet rock, gravel and west coast mud mixed with clay.
In the mud and clay I don't think I have had a tire that gas and clears as well as these do, just, just a wee bit of spin and they were clear and biting. Fantastic tire on the safari on and off road
- driftinglobo
- Driver/Navigator
Hi
Sorry for hijacking
I am looking for some MT s for a Safari and come across this thread.
As it has been some time since the last post in this thread, and I was wondering if you still happy how these MT's preformed over summer? How do they wear on aprox how many kms, and on what vehicles?
Thanks
Sorry for hijacking
Thanks
- Suza
driftinglobo wrote:Hi
Sorry for hijacking
Thanks
Still pretty happy with the tyres, I would think that I have done around the 20-25k mark on them now and they are wearing very well. Haven't done a lot of off road on them this summer due to work being nuts but I have noticed that they do create a distinctive howl on a hot road, doesn't bother me but if you are worried about tyre howl they may not be the right tyre for you.
I usually buy a new set of tyres every 2 years and with the current wear rates I can't see that happening, and when I do at this stage I can't see why I wont be getting another set
- driftinglobo
- Driver/Navigator
Hi Suza
Thanks for the info, sound like these may be my next set. A bit of road noise don't bother me, as much as paying over $350 for a big brand tyre.
May I ask is your Safari Long or SWB? Turbo or NA? As I had read it in an other tread that you not loosing too much power running 33"s.
For my new set I am thinking between 32" x15r or 285/75x16r,(33") but as usual over done the web search on fuel consumption, power loss, for an non turbo safari.
Thanks
I run 33x12.5x15 for size as for me on the Safari they work well without robbing power.
Thanks
- Suza
Happy to share. LWB NA td42 manual . Mine seems to be a bit different to other NA Safari's in that it isn't gutless though as some of them are
Users browsing this forum: No registered users and 34 guests
