Hdj81 both wheels leaning drivers side at the top
pudd99
Postby pudd99 » Tue Dec 29, 2020 9:32 am
What have i bent?
Both front wheels leaning to the drivers side at the top \ \ king pins and everything else seem fine that i can see.. would axle and housing bent cause this?
Thanks
Beer is not the answer... beer is the question, yes is the answer
Big
Re: Hdj81 both wheels leaning drivers side at the top
Postby Big » Mon Jan 18, 2021 6:26 pm
got a picture ?
pudd99
Postby pudd99 » Tue Jan 19, 2021 7:36 am
Its about the same both sides, i have checked king pins and bearings.
I suspect iv bent something serious?
BlakeNZ
Postby BlakeNZ » Tue Jan 19, 2021 8:09 pm
I reckon an experienced 4wd wheel alignment guy would diagnose that in 5 minutes.
pudd99
Postby pudd99 » Wed Jan 20, 2021 11:46 am
Yeah hard to find one in wanaka though
Big
Postby Big » Wed Jan 20, 2021 11:49 am
looks like the king pinss have been installed wrong ? otherwise there is no way they should be like that..check them to see if they have colapsed.. lift the front axle and push pull top and botton to see if there is any movement..
pudd99
Postby pudd99 » Thu Jan 21, 2021 8:26 am
No movement in kingpins, iv checked them also, and their bearings are ok too.. might just havto bite the bullet and take it to the shop
churchill
Postby churchill » Thu Jan 21, 2021 8:59 am
Thr drivers side looks normal, but the passenger side is the one I would be worried about. It could just be a bent housing.
pudd99
Postby pudd99 » Thu Jan 21, 2021 6:38 pm
Yeah man, using a straifght edge and good eyesight the drivers side is just as bad, could anyone help me in the way of finding a new housing?
Return to “Having problems?”
