laser bore sighting tools
waypa
Postby waypa » Wed May 28, 2014 6:13 pm
has anyone had exprence with these new red laser bore sighting tools are they any good or not
mudy1
Re: laser bore sighting tools
Postby mudy1 » Wed May 28, 2014 6:18 pm
hi my one is a golden future laser bore sight collimator and it works very well. :)
Dannz71
Postby Dannz71 » Wed May 28, 2014 6:58 pm
yea ive used 1 b4 and found it good,
Easilily gets it on the chart at 100
stu_71
Postby stu_71 » Wed May 28, 2014 7:36 pm
I asked the same thing on the hunting forum and got a resounding "waste of cash" response. So I never bought one.
You can get the same accuracy by lining up the scope and looking down the bore at the same point. Then start at the range at 50m
Mud Hog
Postby Mud Hog » Wed May 28, 2014 8:01 pm
I got a bushnell one I find it useful. Yeah you can eye down the bore but I find it more accurate using the bore sighter. Saves ammo especially if you have a few guns and always tinkering. I found it handy sighting in the laser dot on the shotgun.
GU patrol 35s ect.
Colinl
Postby Colinl » Thu May 29, 2014 8:07 am
Handy if you are shooting a semi or have a high cheek rest that blocks your line of sight thru the barrel.
You can buy one that is specific for your caliber and chamber inside the firearm they are good for getting you on paper for 50m.
The ones that are aligned from the muzzle but that relies partly on how concentric the crown is to the bore.
sometimes cheap rifles the bore is not concentric to the OD of the barrel!
My 2c.
muddymatt1973
Postby muddymatt1973 » Thu May 29, 2014 8:18 am
I bought a cheap one from Tard-Me and it was crap. It was so poorly made that every time you removed and replaced it in the chamber, the dot appeared in a different place! When insterted you could put your finger on the back and actually wiggle it in the chamber.
My rifle is not shot out, the chamber and bore are fine and it shoots 3 inch groups at 200m.
I sent it back and got my money refunded.
derk
Postby derk » Thu May 29, 2014 9:24 am
you can go and spend some money on a flash laser that does the same as the free eye-ometer that's been used successfully for bore sighting for as long as they have been making firearms :D
Colinl
Postby Colinl » Thu May 29, 2014 1:11 pm
muddymatt1973 wrote:I bought a cheap one from Tard-Me and it was crap. It was so poorly made that every time you removed and replaced it in the chamber, the dot appeared in a different place! When insterted you could put your finger on the back and actually wiggle it in the chamber.
"I you pay fugg all you get fugg all"
meece4x4
Postby meece4x4 » Mon Jun 02, 2014 5:46 pm
stu_71 wrote:I asked the same thing on the hunting forum and got a resounding "waste of cash" response. So I never bought one.
yep I only use this method on my guns ... usually no more than 3 inchs out at 100m
Return to “Hunting”
