This spacer allows you to run IFS wheel hubs on a solid axle front end. IFS wheel hubs wheel mounting face is offset further to allow the front ends of these trucks to match up to the rear, which is 58 inch's wide.
A pair of these CNC machined spacers is needed to adapt either your current solid axle rotors and calipers, or the upgraded IFS calipers and FJ-60 series vented rotors.
We supply all needed hardware to bolt this spacer to the rotor. Dowel pins are no longer used as the adapter has a pair of dowels machined into it, to use factory holes in the disc. The kit includes 6 bolts to mount disc, and is yellow zinc plated for corrosion protection.
$485 inc gst Purchase from our website http://www.snr4x4.co.nz
IFS Hub Spacer Kit
Moderator: Vendors
IFS Hub Spacer Kit
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Re: IFS Hub Spacer Kit
nice, looked through ya site, are you looking to or do you make/sell low profile gearbox mount for hilux
J_Dub wrote:nice, looked through ya site, are you looking to or do you make/sell low profile gearbox mount for hilux
I already told him he needs to make them
i would be keen on one if your going to make them!
andrew007 wrote:i would be keen on one if your going to make them!
well thats 2 orders
ok ok ok I get teh message
Whats everyones chassis and engine/gbox combo that wants one
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Jafa wrote:ok ok ok I get teh message
do a measure on mine should suit all with 60series and standard gearbox ill test it out and you can give it to me for free
mines all standard yn60 5 spd manual, do you want g/b model? how muchy we looking at????????
- hosehustler
Isn't this an IFS hub spacer thread
The SNR kit is awesome.....BUY IT
How about a low profile Xmember for the A340 trans Trev..........
I hate signatures
- muddyhilux
can anyone confirm the fj 60 vented disc part number for appco or the likes,doing this now on brother n laws but his parts guys reckons he cant find the discs?cheers for any help
Users browsing this forum: No registered users and 4 guests
