Wheel Spacers
Moderator: Vendors
Wheel Spacers
These bolt on wheel spacers are designed to give you a little more width without changing out your axle for a wider one. Great for use on solid axles conversions to make the front axle similar in width the wider rear axle found on 86 and up Toyota trucks. Bolt pattern is 6 stud on a 5.5" PCD.
Features safety graded studs and matching nuts for proper fit. Made from Billet 6061-T6 aluminum. Grade 8 Studs, Grade 10.9 nuts. Shipped as a pair of spacers w/nuts.
Five widths available.
25mm $184
31.75mm $205
38.1mm $227
50.8mm $297
76.1mm $372
25mm $184
31.75mm $205
38.1mm $227
50.8mm $297
76.1mm $372
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
- Andrew1706
Re: Wheel Spacers
Just looking for a big of discussion here, whats usually recommended in terms of axle width?
Front and rear the same?
Wider front?
Wider rear?
From factory most solid axles have a wider front axle then the rear, is this for on-road stability when turning etc?
What about from a off-road only point of view?
Wider front?
Wider rear?
Re: Wheel Spacers
Andrew1706 wrote:What about from a off-road only point of view?
The wider it is the more stable it is
Re: Wheel Spacers
this may help with the fj40 too and get rid of that 10mm plate behind the front rims
Re: Wheel Spacers
whats the legality of certing these? thought I read somewhere that the max you could certify was 27mm?? for onroad use that is
Re: Wheel Spacers
moo wrote:whats the legality of certing these? thought I read somewhere that the max you could certify was 27mm?? for onroad use that is
Non of them meet LVVT rules.
Re: Wheel Spacers
Cant run them on the road , if you get caught you will go for a row of shit cans
Re: Wheel Spacers
20mm is the maximum thickness you can get certed, unless the spacer is to effect a change in stud pattern, in which case it can be 27mm thick.
http://www.lvvta.org.nz/stdWheels&Tyres.pdf
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
- muddyhilux
Re: Wheel Spacers
have they changed it again?it used to be 25mm bolt ons where fine for certification?dam if these aint legal i may have to cancel that hold on the set of 4 jafa cos these where going on a road legel truck
Re: Wheel Spacers
muddyhilux wrote:have they changed it again?it used to be 25mm bolt ons where fine for certification?dam if these aint legal i may have to cancel that hold on the set of 4 jafa cos these where going on a road legel truck
Double check with your certifier
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
- muddyhilux
Re: Wheel Spacers
yeh ill call him in the morning,when i talked to him re these for my truck a year ago it was sweet,but yeh,lvvc change thier mind faster than i can eat a double scoop chocolated dipped with sprinkles ice cream from mr wippy and thats dam fast
Re: Wheel Spacers
What kind of strain would these put on everything else? And also can someone tell me if these would be equivalent of an ifs hub swap on a solid axle surf? Trailer my mud tyres everywhere so no major for the road legalness.
- muddyhilux
Re: Wheel Spacers
just xtra pressure on bearings as the force is inlarged by the wheel having more leverage due to being further from axis,i think that made sense and yes i do belive it is the same
Re: Wheel Spacers
thay are only a legal if u get caught just like reg & wofs
its not how big the 4x4 is its how angry the diver is
Re: Wheel Spacers
muddyhilux wrote:just xtra pressure on bearings as the force is inlarged by the wheel having more leverage due to being further from axis,i think that made sense and yes i do belive it is the same
nope the ifs spacer shifts the disc no extra pressure to the bearings etc
Re: Wheel Spacers
muddyhilux wrote:hi all,just been in touch with certifyer and has confirmed for me 20mm "slip on" spacers,ie not bolted on are maximum,however when u go to the adaptor style,ie bolt the spacer on then bolt rim to spacer on 2nd set of studs your allowed 27mm for road only vechiles and 25mm for track / road cars,thats y everyone makes 25mm adapotors because theyre more likley to be brought by someone for track car and 2mm is piss all
hope that clears it up but as always check with your specific certifyer as not all guys are the same
After re-reading the lvvta document, I think this is correct, but it pays to check with your cert guy first
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
- muddyhilux
Re: Wheel Spacers
oh sorry bout the ifs spacer miss info,thanks for the corection hanzy
Re: Wheel Spacers
fj40 wrote:thay are only a legal if u get caught just like reg & wofs
Agreed .
- Dr_PC
Re: Wheel Spacers
Jafa wrote:These bolt on wheel spacers are designed to give you a little more width without changing out your axle for a wider one. Great for use on solid axles conversions to make the front axle similar in width the wider rear axle found on 86 and up Toyota trucks. Bolt pattern is 6 stud on a 5.5" PCD.
25mm $184
31.75mm $205
38.1mm $227
50.8mm $297
76.1mm $372
Just fitted my 50mm spacers today, had them sitting in the shed for a couple of weeks , you know walk past give them a pat..
Arrived look as good as the pictures everything fitted damm good product and I couldn't make them for the price that I purchased them for.
Re: Wheel Spacers
fittrd my 50mm spacers today real nice product took less than an hour to fit
Death to the competition
Re: Wheel Spacers
am looking for a set to suit zuk grand vitara rims only want bout 15 mm can you help or send me in the right direction
thanks
Warren
thanks
Warren
Re: Wheel Spacers
I don't think you will find spacers like the bolt on ones for 15mm.
As the nut needs to be rebated into the spacer.
The thinnest is 25mm...
Other option is to use a packer...
May need longer wheel studs.
Also from memory the packer needs to be retained on the hub or wheel....
Calvin
Calvin
- bigboar357
- Driver/Navigator
Re: Wheel Spacers
i bourt a set of 25mm afew months ago from a guy in palmerston north he tald me i didnt need to get a cert and i put them on my truck last months went to get a wof and they said i needed to get it cert so im seeling them i payed $220 for them.i want $150 for them if any 1 keen send me a pm
Re: Wheel Spacers
You used to be able to fit wheel adapters..
But the new WOF rules state any spacers / adapters need cert now.
Have a read of the rules out as of April 2011
http://www.nzta.govt.nz/resources/virm- ... s-v4a2.pdf
Hmmmm
Calvin
Hmmmm
Calvin
Re: Wheel Spacers
bigboar357 wrote:i bourt a set of 25mm afew months ago from a guy in palmerston north he tald me i didnt need to get a cert and i put them on my truck last months went to get a wof and they said i needed to get it cert so im seeling them i payed $220 for them.i want $150 for them if any 1 keen send me a pm
Take them off an get your wof then put them back on??
Didn't barbie drive a jeep??
Re: Wheel Spacers
Fakey wrote:Take them off an get your wof then put them back on??
The only problem with that is... You get in a road accident....
Car is inspected and spacers found not certified...
No insurance......Plus other fines. Even if you are in the right...
Calvin
Re: Wheel Spacers
aroma wrote:am looking for a set to suit zuk grand vitara rims only want bout 15 mm can you help or send me in the right direction
thanks
Warren
We have 5/139.7 25mm spacers
- MNC
Re: Wheel Spacers
I have a single spare 30mm 6 stud spacer if anyone has another that would be useful.
Re: Wheel Spacers
kbushnz wrote:Fakey wrote:Take them off an get your wof then put them back on??
Calvin
Are you sure? This is only what ive been told by an ex insurance assessor but to not pay out theyd have to prove that the wheelspacers contributed to the accident in some way
- bigboar357
- Driver/Navigator
Re: Wheel Spacers
Fakey wrote:kbushnz wrote:Fakey wrote:Take them off an get your wof then put them back on??
Calvin
yep if u have them on and you have a accident and they on there and they not cert you dont get no insurance.i asked a friend who wife works for a insurance place.they wont pay out if they find anything rong or not ment to be on there without being cert
Users browsing this forum: No registered users and 16 guests
