Now suppling Beadlocking sets, These are 36 stud type 15" rim sets that can also be certified for on road use. Come in the following options and or part build:
1. D.I.Y set comprising of the 8x rings only
2. Full set (4x) fitted to your rims (off road use)
2. Full set (4x) fitted to your rims (on road use)
3. 144x 8.8 tensile bolts with washers & Nyloc nuts
4. Wheel splitting only
5. Spare wheel
http://www.williams4x4.co.nz
BEADLOCKER SETS
Moderator: Vendors
Re: BEADLOCKER SETS
Storm wrote:Now suppling Beadlocking sets, These are 36 stud type 15" rim sets that can also be certified for on road use. Come in the following options and or part build:
5. Spare wheel
Awesome, do you have the pricing sorted for each option yet and how thick are the rings.? Cheers
Re: BEADLOCKER SETS
Hi, I am trying to give all the options here for the guys who want to put them together themselves given most here are capable of using the Mig welder Rim splitting $19.30 per rim. 15" twin disc set for 4x wheels is $545 but this is the road legal certifiable spec. The plates are and have to be the legal 6mm steel.
Example, your rims couriered to our works and full bead-lockers fitted, drilled ready for new placement of valves (also primed & painted in standard white or black) $125 per rim.
Spare "extra" wheel $210.00
I decided it best to offer one single standard set that covers both on road/off road. Double bead locks can also be done no problem. Trust this helps, Craig.
Users browsing this forum: No registered users and 4 guests
