Hilux and Landcruiser Front Axle Rebuild Parts
Moderator: Vendors
Re: Hilux and Landcruiser Front Axle Rebuild Parts
Tim, I dropped you a PM Yesterday. If you can confirm what I asked I will stop looking elsewhere for the bits.
Sorry, didn't get the PM, try again or post on here
Tim
Hi,
Have you changed your screen name?
I thought I sent it to 4wdstuff yesterday and I have just sent one to suzolla which seems to have taken up residence in my outbox.
This is what I was trying to find out.
C an you tell me if the 54mm Hub Spanners you have for the Toyotas will fit my GQ60 Front Hubs, I have seen elsewhere online that the nuts are 54mm across flats so that part looks like it matches it is the depth I am inquiring about.
If so would I be able to order one , pay with my ANZ Visa and have you post it to me in Northland?
Hi Tim.. do you still have rebuild kit for the front of the 80.. ta.. not having much luck just finding bearing alone..
Hi Keri,
Yes have still got some diff rebuild kits
Tim
Tim
make it so batman.. cant remember the price but I neeeeed them.. Sharp as a tack cheers tim.. you been very helpful. K
Hey Tim
Do you do solid pinion spacers with shims like the trailgear ones if so how much for a v6 one posted to Blenheim
Cheers Leigh
Cheers Leigh
Keri,
Posted, hopefully the courier picked them up today, not sure if I was in time.
Tim
Tim
Thanks Tim..
Hey Tim.. me again.. don't suppose you have a 29 spline flange for the front rebuild im doing? to suit new r & p's.. need one asap..could you txt me if you do.. TA
Hi Keri,
Got 2 options
Nitro are $110 each and the Sliverback are $85 each.
Do you need flange, seal and nut. Prices above is for everything.
Tim
www.4wdstuff.co.nz
Got 2 options
Tim
www.4wdstuff.co.nz
Hi Tim, just the flange.. as new nut and seal is already here..
Hi Tim.. those wiper seals not too flash ..about 1/2 cup water in each knuckle( didn't want to fill entire knuckle with grease).. so trying something different.. do you still have Trail Safe Toyota Knuckle Ball Polyurethane Wiper Seals and Rock Rings ? for the 80 or something like them.. as not having much joy here.. and seeing as I have to pull the front down to install new wipers etc.. let me know what ya got eh..otherwise positive air is going in..lol
Hi Kerry,
Thats a bit of a bugger, bit strange as they were meant to be good, although would agree that having the cut in them increases the likelihood of them leaking.
As for the Polyurethane Wiper Seals and Rock Rings, haven't come across any for the 80 series yet.
Tim
Tim
hi tim just wondering if you got my pm? need parts asap cheers
Hi Adam,
Yes sorry, been really busy, will reply this afternoon, have all parts except gun drilled Longs as these are only new.
Tim
Tim
hi tim it won't let me pm you. just wondering if you have got my pms cheers
Users browsing this forum: No registered users and 31 guests
