Air Locker For Sale Yukon Zip locker for Toyota 8" New
Moderator: Vendors
suzolla
Postby suzolla » Sat Dec 22, 2012 11:09 pm
Hi,
Have got a couple of New Yukon Zip lockers for sale.
http://www.yukongear.com/ProductDetails.aspx?ProdID=11118
The Yukon are assembled in the USA so more likely to have been inspected throughly prior to assembly.
Similar to ARB.
Can do for $1200 incl post for the V6 housings
and
Can do for $1300 incl post for the 4 cyl housings as you need new side bearings.
PM me if interested.
Tim
suzolla
Re: Air Locker For Sale Yukon Zip locker for Toyota 8" New
Postby suzolla » Fri Jan 18, 2013 4:34 pm
Bump.
See first post
PM me if interested
Tim
suzolla
Postby suzolla » Tue Jan 29, 2013 12:29 pm
Bump.
See first post
PM me if interested
Tim
suzolla
Postby suzolla » Fri Feb 08, 2013 9:36 am
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Mon Feb 25, 2013 12:25 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Mon Mar 18, 2013 9:15 am
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Sat Apr 13, 2013 10:26 pm
Bump.
See First post
PM me if interested
Tim
Big
Postby Big » Sun Apr 14, 2013 12:37 pm
which would fit the 80? Cheers
suzolla
Postby suzolla » Sun Apr 14, 2013 9:28 pm
Should fit straight into the front high pinion using your existing bearings.
Tim
Big
Postby Big » Sun Apr 14, 2013 10:28 pm
thanks..
suzolla
Postby suzolla » Thu May 02, 2013 10:25 am
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Sun May 19, 2013 2:30 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Thu Jun 13, 2013 10:23 am
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Fri Jul 05, 2013 4:41 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Fri Jul 19, 2013 9:51 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Thu Aug 08, 2013 8:51 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Mon Aug 26, 2013 1:25 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Mon Sep 16, 2013 4:39 pm
Bump.
See First post
PM me if interested
Tim
dutchy
Postby dutchy » Tue Sep 17, 2013 4:58 pm
Would these fit a kzn130? also does it require a special compressor or would a generic twin piston work?
Surf - 50mm lift, front bar, integrated winch etc
contactable on 0220901730
suzolla
Postby suzolla » Wed Sep 18, 2013 10:40 am
Yes will go in the back, any comp will do just needs to be the correct pressure.
Tim
suzolla
Postby suzolla » Mon Oct 07, 2013 10:03 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Mon Nov 04, 2013 12:22 pm
Bump.
See first post
PM me if interested
Tim
suzolla
Postby suzolla » Tue Dec 03, 2013 9:13 am
Bump.
See First post
PM me if interested
Tim
Big
Postby Big » Mon Dec 09, 2013 6:42 pm
still got some ? as Santa might be good to me.. also strength.. can handle a bit? as you know.. got a blower now.. :shock: and the figures are good..lol
suzolla
Postby suzolla » Mon Dec 09, 2013 8:53 pm
Hi, yes still got a couple, regarding strength, don't have any personal experience, looking on the web Yukon certainly seem to think they are good, got a vid of a Dana30 locker breaking five 4340 axles at about 6500 ftlbs with no damage to the locker, compared with the ARB video in 2009 showing a Zip locker failing at about 6500 ftlbs because the locker case split, looked like a cast material type failure where as they now say it is forged which will be much stronger. Only you can decide what to do.
Tim
Big
Postby Big » Tue Dec 10, 2013 7:11 am
Cheers ..
suzolla
Postby suzolla » Tue Dec 10, 2013 7:45 pm
Hi,
I emailed Yukon about the ARB video to see what the story was, below is their reply.
In regards to the Zip locker in the ARB video, this was a pre-production unit that was not meant to be sent out to customers, we are still not sure how they got ahold of it but I can assure you that all of our Zip lockers are forged. The Zip locker has the best warranty in the business, a 6 year, $2000 collateral damage warranty blows our competitions warranty out of the water. The reason we can offer this kind of warranty is because our Zip lockers have proved to be extremely durable and as far as a “failure point” I cannot answer that as we have yet to see one. Our competitors warranty is very strict, in other words they do not honor ANY warranty if their product is used in “competition,” where we set no such limitations.
He also said the warranty is only valid for the original owner, ie did not cover 2nd hand lockers.
Tim
Big
Postby Big » Tue Dec 10, 2013 9:33 pm
Do you have them for the rear..? 9.5 ff.. ta
Return to “Axles Tyres and Wheels”
