Toyota 80 Seri LJ, KZJ Susp Leading, Trailing Arm Bushes F/S
Moderator: Vendors
suzolla
Postby suzolla » Sat Dec 29, 2012 10:02 pm
Hi,
Have got some more bushes.
For previous thread on these see http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=67&t=31587
Got some 48702-60050 which are listed as 80 series front arm bushes. These go at the axle end of the arm, 4 are required for a complete set. Can do these for $55 each incl post GOT PLENTY NOW
Dimensions are
ID 16mm, Length 50mm, OD 60mm, Length 40mm
So these also fit the axle end of the KZJ and LJ TRAILING arms plus they fit the axle end of the KZJ LEADING arms on the front.
ALSO my understanding is that they fit the axle end of the Nissan Safari Front Leading Arms.
Last time some 48702-60060 which are listed as rear arm bushes for post 1990 KZJ's and LJ's These where $65 each incl post Decided not to get any of these as they are essentially the same as the 80 Series ones but $10 dearer. So for your LJ and KZJ use the 80 Series ones.
Much cheaper than the $150 to $200 each I was quoted by Toyota.
Also got some of the bushes that go in the Chassis end of the 80 Series Leading arms
Part no is; Bush, Lower Arm 48061-60010
Dimensions are
ID 18mm, Length 60mm, OD 54mm, Length 40.5mm
These are $65 each including post.
Plus got some 80 series rear upper and lower control arm bushes.
Bush Sub Assy, Upper Control Arm 48702-60031
Dimensions are
ID 18mm, Length 60mm, OD 50mm, Length 45mm
These are $55 each including post.
Bush Sub Assy, Lower Control Arm 48702-60040
Dimensions are
ID 18mm, Length 60mm, OD 55mm, Length 45mm
Also some KZJ78 or LJ7? Leading and Trailing arm Chassis End Bushes, these are different to the 80 Series ones.
Part no is; Bush Sub Assy, Leading Arm No2 48061-60020
All are genuine Toyota parts.
PM me if interested.
Tim
suzolla
Re: Toyota 80 Ser Susp Bushes and LJ, KZJ Trail Arm Bushes F
Postby suzolla » Sun Jan 20, 2013 11:31 pm
Bump
See first post
PM me if interested
Tim
suzolla
Postby suzolla » Sun Feb 03, 2013 7:04 am
Bump
See first post
PM me if interested
Tim
suzolla
Postby suzolla » Sat Feb 09, 2013 9:18 pm
Bump
See first post
PM me if interested
Tim
suzolla
Postby suzolla » Mon Feb 25, 2013 12:27 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Mon Mar 18, 2013 9:16 am
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Sat Apr 13, 2013 10:27 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Tue Apr 30, 2013 10:17 am
Bump.
See First post
PM me if interested
Tim
suzolla
Re: Toyota 80 Seri LJ, KZJ Susp Leading, Trailing Arm Bushes
Postby suzolla » Mon May 13, 2013 1:25 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Tue Jun 11, 2013 5:46 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Sat Jun 29, 2013 9:41 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Fri Jul 19, 2013 9:48 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Thu Aug 08, 2013 8:47 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Tue Aug 20, 2013 10:35 pm
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Sun Sep 08, 2013 11:54 am
Bump.
See First post
PM me if interested
Tim
suzolla
Postby suzolla » Wed Oct 02, 2013 10:40 pm
Bump.
See first post
PM me if interested
Tim
suzolla
Postby suzolla » Thu Oct 31, 2013 1:13 pm
Bump.
See first post
PM me if interested
Tim
suzolla
Postby suzolla » Sun Apr 13, 2014 6:23 pm
Bump.
See first post
PM me if interested
Tim
http://www.4wdstuff.co.nz
80 Series 1HDT Auto 2" Lift 33's running on Transformer Oil Road Truck
80 Series 1HDT Man Std at the moment, Plans to modify for Off Road
crazydragon
Postby crazydragon » Sun Apr 19, 2015 10:51 pm
Hi Tim,
Not sure if you still have any, but looking for a set for my KZJ78.
Cheers!
4wdstuff
Postby 4wdstuff » Mon Apr 20, 2015 1:21 pm
Hi,
Yes should have, have a look at http://www.4wdstuff.co.nz/catalog/toyot ... suspension and let me know which ones you want.
Tim
4wdstuff.co.nz
crazydragon
Postby crazydragon » Tue Apr 21, 2015 5:55 pm
Hi Tim,
I would like to purchase 4x axle end bushes. The $55 ones. Those are the ones attaching to the axle and the arms I'm guessing?
Where abouts is your shop? Can I pay cash on pick up?
Kevin
4wdstuff
Postby 4wdstuff » Fri May 08, 2015 4:46 pm
Hi Kevin, yes that is correct axle end.
Have sent you a pm.
Tim
crazydragon
Postby crazydragon » Tue May 19, 2015 9:20 am
Highly recommend Tim if you're after some factory bushes for your Toyota. So much cheaper for the same product. Way better than those Polyurethane ones. Thank you!
4wdstuff
Postby 4wdstuff » Tue May 19, 2015 10:07 am
Thanks for the endorsement Kevin
Tim
Return to “Suspension”
Users browsing this forum: No registered users and 1 guest
