Got Some More Optima Batteries
Moderator: Vendors
Hi,
As the title says I have got some more batteries as per below.
Optima 8004-003 Red Top Starting AGM Battery 34/78 CCA 800 amps Can do these for $350 plus post.
Optima 8012-021 Yellow Top Deep Cycle & Starting AGM Battery D34, CCA 750 amps. Can do these for $425 plus post.
Optima 8012-045 Yellow Top Deep Cycle & Starting AGM Battery D34/78, CCA 750 amps. Can do these for $435 plus post.
Optima 8051-160 YellowTop Deep Cycle & Starting AGM Battery D31A, CCA 900 amps. Can do these for $525 plus post
Post to Auck $10, Lower Nth Is $15 and Sth Is $25.
If interested send me an email on 4wdstufftim@gmail.com
Tim
Tim
- mike
- Last minute Mike
Re: Got Some More Optima Batteries
I've had optima batteries for ten years in my truck now, the same ones. Multiple times flat (both of them, usual story, lights on slow drain oops), used in anger for long winches, winch comps etc. Both going strong but obviously not as good as when I got them but still pretty bloody awesome. It would take a bit of persuasion for me to go to something else Just thought I would put that out there if you thought the price of these things are expensive. Over ten years it works out bloody cheap!
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
what one would you recommend for a 2.7td terrano with the usual accessories, 9500 winch and spot lights?
Yellow top if using a winch, red is more just for starting with light electrical loads.
Bigger the better if it will fit. If doing alot of winching 2 is even better.
Only difference between the D34 and D34/78 is the D34/78 has a couple of extra terminals on the side for connecting to.
Tim
Tim
Bump
Tim
Tim
Bump
Tim
Tim
wow, these are really sharp prices.
Bump
Tim
Tim
finally looking at another one Tim.. got any deals going ? big is better
Hi Keri,
Sold out of the big ones at the moment, getting some more in next shipment.
Will send you a PM
Tim
Will send you a PM
Tim
Bump.
http://www.4wdstuff.co.nz/batteries-opt ... a-750-amps will do for $400
http://www.4wdstuff.co.nz/batteries-opt ... a-750-amps will do for $410
http://www.4wdstuff.co.nz/batteries-opt ... a-900-amps
Tim
Tim
Any blueys? I think it was M34 I was looking at
1989 LWB 5-Seat parts hack. TD42
Sorry only Yellows, any particular reason you want Blues
Tim
Tim
- Crawlerer79
Hi Tim,
When will the Red Top batteries be back in stock.
It's nearly time for my Landies battery to be replaced
Tim
Tim
'Lando' - 1994 V8 Disco
Users browsing this forum: No registered users and 6 guests
