worsleys
- crazyclark31
worsleys
Hi all. am up in chch for a week. and am keen to go for a bit of 4wding. Have heard this road is a bit of a challenge. Seeing as its flat around home and pretty much mud am keen to try some more tech driving for a change.
Truck is a lwb safari. 2in lift 33s but no lockers,winch,have front,and rear bar work and sliders to. Do have a thinking driver tho . As far as damage goes well if it happens it happens but do try to avoid it untill the red mist sets in .
Basically after a bit of a challenge/mission for an arvo. Have all my recovery gear incl ground anchor.
Mike
Mike
- drive it ...
Re: worsleys
Tied up till after easter, could do an after work run on Tue or Wed if you're still around then. If no one fronts up its actually pretty ok as a solo run, hi-lift and some bits of wood is just as likely to get you out of trouble as a snatch from another truck. Not much to winch off up there. Real good idea to get out and walk sections to plan your line rather than just drive in and get hung up in a hole.
Re: worsleys
ill come for a wee drive up, pretty simple track just depends on your lines make it as hard as you want really
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
(027 788 1046)
Re: worsleys
ild be pretty keen too, time to get my poor old surf out there again now shes fully mended.
A day and time you had in mind?
gigidy gigidy gigidy goo
- crazyclark31
Re: worsleys
Am up here for the Canoe polo oceania comp been held at lake roto kohatu which starts on friday so was looking at heading up tomorrow arvo for a look.
Am happy to wander up by myself but better when theres more than one.
You guys have a meeting spot you use? Say oneish
Re: worsleys
bugger, im working tomorrow, was hoping you were talking about the weekend.
sorry then mate but I wont make it then, gotta earn some money to feed the monster before it goes off road
- crazyclark31
Re: worsleys
All good mate. I here ya on that one re feeding the monster.. Me i'm just lucky to have good boss. Me
- crazyclark31
Re: worsleys
went up worsleys today. Man that is a fun track. Took all the right hand tracks that are currently being used and was sweet as.
It was a real nice change to get to do something other than mud. Can see why some of you guys like the rocks.
Am seriously looking at going back in weekend and have a real good play in some of those ruts.
Vids to come
Vids to come
Re: worsleys
Is this worsley on the port hills in CHCH?
I've got a surf with a 2" lift and 32 AT's - cautious beginner driver.
Edit: Just read another couple of threads on this track. ha ha might give it a miss till i know what im doing. Might go for a nose tho (on foot!).
Re: worsleys
jt3000 wrote:Is this worsley on the port hills in CHCH?
Give me a text might be able to take you for a ride up the hill some time
Cheers Jordan
(number down)
(027 788 1046)
(027 788 1046)
Re: worsleys
id be keen to go up,, landy on 32'' should make it up..?
Re: worsleys
Would be good to watch a few trucks go up, let me know when yas are heading up, ill come watch
- hosehustler
- mike
- Last minute Mike
Re: worsleys
ef9 wrote:id be keen to go up,, landy on 32'' should make it up..?
a landy will go anywhere just on coolness factor alone
unless worsleys has changed you should be able to pick your lines carefully in the dry and get through with little or no help. Wet, well then all cards are up in the air and I'd just follow hosehustler
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
Re: worsleys
mike wrote: Wet, well then all cards are up in the air and I'd just follow hosehustler
And hope he will stop and pull you through......
To be fair, this track is waaayyyyy more fun when it is dry. You can really push the envelope
- tomsoffroad
- Flopsie
Re: worsleys
Might be time for your yearly dementia check Mike
Make sure whoever is following Hosehustler up there has lots of windscreen washer water
Users browsing this forum: No registered users and 29 guests
