Give yourself super low ratios for the ultimate in crawlability!, fitting a Trail-Gear dual case adapter will give double low range and 20 forward gears, a gear for any occasion
This dual case adapter has greatly increased oiling flow in and around the adapter for cooler operation. We have increased the strength of the casting by making thicker walls and creating huge oversized gussets. A special retainer ring securely stabilizes the main bearing to prevent bearing play. Other adapters in the market only use a light gauge snap ring to hold the bearing in place. Tight tolerances on the coupler ensure long life and prevent striped out input gears.
Installation requires an additional top shifting Toyota gear-driven transfer case, drive shaft modifications, and floorboard modifications. Assembled dual adapter unit is 6.5" long.
Kit Includes:
* Heavy duty aluminum adapter plate
* Heavy duty coupler
* Cage & main bearings installed
* Replacement transmission output seal
* Magnetic drain plug
* Shift knob
* Mounting hardware
* Transfer case and transmission block off plates
$894 inc gst Purchase from our website http://www.snr4x4.co.nz
Dual Case Adapters
Moderator: Vendors
Dual Case Adapters
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
