Toyota MR2 Caliper Coversion kit
Moderator: Vendors
callum007
Re: Toyota MR2 Caliper Coversion kit
Postby callum007 » Tue Jul 21, 2009 1:32 pm
at the risk of sounding dumb.. what rotors are you usually fitting to replace the drums on hilux rear?? dont think i'll need to change mine over, its prob going to have a front end at the back :wink: :wink:
Jafa
Postby Jafa » Tue Jul 21, 2009 1:37 pm
Prado rears
021 273 9942
jafa@inspire.net.nz
Postby coxsy » Tue Jul 21, 2009 2:31 pm
any word on the cruiser brackets jafa
Postby Sadam_Husain » Tue Jul 21, 2009 2:45 pm
coxsy wrote:any word on the cruiser brackets jafa
I've got a set of brackets for subaru callipers here coxsy
chevrolux
Postby chevrolux » Wed Dec 09, 2009 7:09 pm
Im going to do this conversion and am wondering what discs too get? and if anyone out there has a set they would let me purchase?
haydgq
Postby haydgq » Wed Dec 09, 2009 7:11 pm
chevrolux wrote:Im going to do this conversion and am wondering what discs too get? and if anyone out there has a set they would let me purchase?
I used rear disk's from a 78 series Prado, New from BNT they were around $60 each with a trade disc. :D
nstacey
Postby nstacey » Sun Dec 20, 2009 3:27 pm
Has anyone got any pics of this as a finished product fitted to a leaf sprung hilux? Have you used the original brake cables etc?
85 Hilux single cab
02 Grand Vitara
1rugger
Postby 1rugger » Sun Dec 20, 2009 3:43 pm
had clearance problems with mine & had to get new cables made up as the standard hilux cable pulls in the wrong direction for the mr2 calipers.
89 LN106 Hilux 3.0L turbo,2" bodylift 50mm suspension lift, lockrite rear, lsd front & 33" wranglers & winch
nstacey
Postby nstacey » Sun Dec 20, 2009 3:46 pm
cheers, any pics of end result?
85 Hilux single cab
02 Grand Vitara
1rugger
Postby 1rugger » Mon Dec 21, 2009 11:40 am
here's the thread from when i did it.
just haven't added the photo's of how i cut and re-welded the hand brake lever so it clears the leaf. and used a surf hand brake lever to go from a single cable to two cables (one to each brake). hope this helps
http://www.offroadexpress.co.nz/Forums/ ... 22&t=16569
chevrolux
Postby chevrolux » Sat Jan 02, 2010 11:21 am
so got some callipers from an aw11 mr2 (10 bucks on trademe :D ). they look fairly identical to the sw20 ones. Are the 78 series disks going to fit in there? Or should i grab some ln65 discs? Also, Going to put a proper handbrake on the floor. Will any old handle do? I see bulletproof used a landcruiser handbrake lever. People have any prefernces? Oh and any old equalizer does the trick for the handbrake cables?
Return to “Axles Tyres and Wheels”
