New Uniden 80ch NB PRS Radios
Moderator: Vendors
New Uniden 80ch Narrow Band Radios are out
This is my pricing (to be confirmed) if anyone wants one, can look at a bulk buy if enough people interested. will update the marketplace soon
7700nb $255
http://uniden.co.nz/NEW_ZEALAND/p_uh7700nb_index.asp
7760nb $340
http://uniden.co.nz/NEW_ZEALAND/p_uh7760nb_index.asp
7700nb+1 $299
http://uniden.co.nz/NEW_ZEALAND/p_uh7700nb_1_index.asp
still got some aerial kits in stock, can do new uniden CBs as well
prices INCLUDE gst, add freight to this, pricing may be subject to change etc.
7700nb $255
7760nb $340
7700nb+1 $299
Re: New Uniden 80ch NB PRS Radios
do these work with regular 477prs jerry??
DIRTY OLD HILUX
022 519 7700
022 519 7700
Yes these work on the current UHF PRS frequencies as well as the new narrow band ones which are inbetween the current ones.
put me down for the 255 one can i get it tomorrow
im keen on 1 of the 7700nb $255.cheerrs pressy
Not sure if you know this but ill ask anyway
How do the channels in the 40 line up the 80.
IE 1=1 , 2=2 etc or are they all over the place?
Ive not long ago brought a GME TX3100..... do you know if this can be upgraded to 80 channel?
group buy for the 7700nb i think
put me down for one.
whats the aerial worth for this
Pedro
Pedro
- tara13
I will have a $ 255 and arieal pack Jerry thanks Gareth
tallsam66 wrote:Not sure if you know this but ill ask anyway
From reading the Govt site on the new channels it goes like this.
Ch 1 thru 40 current state.
Ch 41 thru 80 start at the frequencies between the current ones.
So moving forward the old units will still work fine just wont get the in-between channels 41 - 80.
Calvin
Had a chat with the local rep, calvin is correct, been waiting for these to be released. All the manufacturers are relasing models. GME and Uniden radios will be at the same price points as the existing models.
Who knew Prados could fly?
- ClassicCruiserSpares
- Sausage Shack
Im Keen on a 7700nb $255 plus arial kit.
Hey Jerry, could be keen on the $255 one as well with aerial kit, anyone know who can install these as I hate touching electrics LOL
1986 2.5L TD Pajero
install is pretty easy, can give you a hand if you want...
- niblik
- Sausage Shack
Jerry wrote:7700nb $255
one of the above plus a soft aerial please jerry..
when ya get pricing through of course, let me know..
niblik wrote:Jerry wrote:7700nb $255
Ditto please Jerry
Yes I would be keen on the $255 and need a price for the aerial?
Aerial kits will be around $55
Will put in the order early next week, those that want them please pm me courier address etc and i will get bact to you etc, aerials and radios come from different suppliers so will be seperate (unless you want a std uniden one). however for main centres eg chch/wgtn I can bulk ship and you pick up etc.
Jerry wrote:Aerial kits will be around $55
Any advantage to using or not using the standard Uniden aerial or is it just a price thing?
Cheers.
Jerry wrote:trees
Sums it up nicely. Cheers.
Hey Jerry, will these already have been upgraded when we get them?
these are new models 80ch ready
that spot on the plastic bumper is going to the least in efficient place on the vehicle you could put it besides the sump.. although those are a ground independant aerial. best place you can install it is somewhere with a metal ground plane . eg centre of your roof...
the reason for the new Narrow band channels is due to wide band frequencies being phased out in commercial applications as is terrestrial tv, means more frequencies are available for us commercial users..
Jerry wrote:these are new models 80ch ready
So will they still need to go back into dealer for the extra channels to be turned on?
ok just had a look at the website
http://uniden.co.nz/NEW_ZEALAND/cs_77_channel_acma.asp
40 NARROW BAND CHANNELS / 77 CHANNEL READY
40 Narrow Band Channels / 77 Channel Ready Uniden
A New Standard
The ACMA (Australian Communications and Media Authority) reviewed the arrangements for the UHF CB band. As a result the ACMA decided to restructure the UHF CB band, increasing its capacity from 40 up to 80 channels – with 75 for voice communications and 2 for telemetry totalling 77 useable channels (the remaining 3 channels are restricted for possible future use). The NZ MED (Ministry of Economic Development) has also agreed to introduce these new channels.
Users will soon see the terms 'Wideband' and 'Narrowband' being used to describe older radios and newer radios. Older radios that operate on only 40 UHF-CB channels are Wideband radios and newer radios that will operate on the 77 UHF-CB channels are Narrowband radios. Both Narrowband radios and Wideband radios can communicate together normally as always on the first 40 channels. Only the new Narrowband radios will have the additional channels up to channel 80.
Launch Timing
The ACMA and NZ MED have estimated a launch date in the coming months, most likely between April to July 2011, from which the new narrowband channels 41 – 80 can be used. In 2017 the ACMA and NZ MED may consider revoking the Radio Communications Class License for any older 40 channel Wideband UHF-CB radios remaining in use.
Uniden – User Upgrade System
All Uniden radios with model numbers ending in NB (Narrow Band) eg UH7700SX-NB are user upgradable to the 77 usable channels when the ACMA and NZ MED confirms the launch date and then to the full 80 channels should the ACMA allow.
Uniden radios have been specially engineered this way as it is the simplest and easiest approach for consumers since it means:
- No upgrade costs $$$
- No hack modifications
- No de-installation, re-installation costs $$$
- No down time
- No problems
Uniden will simply publish on this website the unlock code to enable the additional channels, immediately after the ACMA licences their use.
A Summary of Special Channel Usage in the 80 Channels
• Channels 22 and 23 are reserved for telemetry and telecommand. Voice transmission is prohibited on these channels.
• Channel 61, 62 and 63 are restricted for possible future use. Uniden radios can be user upgraded to use these channels should the ACMA legalise their use.
• There are 16 Duplex channels 1 to 8 (31 to 38) and 41 to 48 (71 to 78).
• Channel 5 (+Duplex 35) remains the emergency channel.
*Please note: in the Narrowband UHF CB Expansion 77 channels are available and user upgradeable for FREE when the ACMA Standard is published, see Uniden's website for details
A New Standard
Launch Timing
- No down time
- No problems
Tats all good Jerry but where my radio
Hi Jerry,
I'm keen on a 7700nb $255
Also a UH720SX-2 two hand helds
Plus an Aerial
Tim
Plus an Aerial
Tim
- rangimotors
same for me please
Is this a one off deal Jerry or can I get back to you when the Money fairy knocks again in a while?
Dead keen but no folding stuff for toys at the moment.
Users browsing this forum: No registered users and 21 guests
