Hilux and Landcruiser Front Axle Rebuild Parts
Moderator: Vendors
suzolla
Postby suzolla » Thu Nov 03, 2011 10:05 pm
Hi,
As the title says i have got a few Trailgear Front Axle Rebuild Parts as listed below.
Toyota Solid Axle Spindle Brass Bushings $60 for the pair
Toyota Rock Ring Knuckle Felt Protectors  $30 for both sides
Rock Ring Extended Stainless Button Head Bolt Kit $20 for both sides
Trail Gear Trail Safe Inner Axle Seals (Sold in Pairs) $25 Image
Trail Safe Toyota Knuckle Ball Polyurethane Wiper Seals and Rock Rings $85 for both sides
Aisin FWH Hub Outer Dial O-Rings $25 for both sides
LONGFIELD TOYOTA KNUCKLE LIFETIME WIPER SEALS Set of 2 $70
Toyota 54mm Wheel Bearing Nut Spindle Socket $25 Image
Hilux Wheel Bearing Inner Grease Seal, also required when doing the IFS Hub Swap.
Plus postage which on most items would only be about $5-$6
PM me if interested
Cheer
Tim
http://www.4wdstuff.co.nz
80 Series 1HDT Auto 2" Lift 33's running on Transformer Oil Road Truck
80 Series 1HDT Man Std at the moment, Plans to modify for Off Road
suzolla
Re: Hilux and Landcruiser Front Axle Rebuild Parts
Postby suzolla » Sun Nov 06, 2011 10:22 pm
Bump,
See first post
Tim
pruggerdore
Postby pruggerdore » Mon Nov 07, 2011 9:48 am
suzolla wrote:Hi,
Toyota Solid Axle Spindle Brass Bushings $50 for the pair
Trail Safe Toyota Knuckle Ball Polyurethane Wiper Seals and Rock Rings $95 for both sides
PM me if interested
Cheer
Tim
Hi Tim is there a website that I can go to look at this stuff. just been on the trailgear site and couldnt find anything.
suzolla
Postby suzolla » Mon Nov 07, 2011 3:28 pm
Hi, most of it is Trailgear stuff but all over the place.
I will put some photos up hopefully tonight
Tim
suzolla
Postby suzolla » Tue Nov 08, 2011 12:45 pm
Will try and do tonight, camera went flat
Tim
suzolla
Postby suzolla » Tue Nov 08, 2011 11:33 pm
Hi,
Have put some photos up of the various parts
PM me if interested
Tim
suzolla
Postby suzolla » Wed Nov 23, 2011 11:29 pm
Hi,
PM me if interested
Tim
suzolla
Postby suzolla » Tue Nov 29, 2011 12:23 pm
Bump
See first post.
PM me if interested
Tim
suzolla
Postby suzolla » Thu Dec 08, 2011 12:23 pm
Bump
See first post
PM me if interested.
Tim
suzolla
Postby suzolla » Mon Dec 12, 2011 4:29 pm
Bump
See first post
Tim
suzolla
Postby suzolla » Thu Jan 19, 2012 9:24 am
Bump,
See first post.
PM me if interested
Tim
suzolla
Postby suzolla » Sat Mar 03, 2012 4:10 pm
Bump,
See first post.
PM me if interested
Tim
suzolla
Postby suzolla » Thu Apr 12, 2012 1:27 pm
Bump,
See first post.
PM me if interested
Tim
suzolla
Postby suzolla » Fri Apr 20, 2012 9:47 pm
Bump,
See first post.
PM me if interested
Tim
suzolla
Postby suzolla » Fri May 18, 2012 12:07 am
Bump,
See first post.
PM me if interested
Tim
Only 2 sockets left
suzolla
Postby suzolla » Thu May 31, 2012 12:45 am
Bump,
See first post.
PM me if interested
Tim
Only 2 sockets left
suzolla
Postby suzolla » Fri Jun 15, 2012 11:40 pm
Bump,
See first post.
PM me if interested
Tim
suzolla
Postby suzolla » Sat Jul 07, 2012 10:36 pm
Bump,
See first post.
PM me if interested
Tim
suzolla
Postby suzolla » Fri Jul 13, 2012 10:37 pm
Bump,
See first post.
PM me if interested
Tim
suzolla
Postby suzolla » Fri Jul 20, 2012 5:39 pm
Bump
See first post
Tim
suzolla
Postby suzolla » Fri Jul 27, 2012 10:34 am
Bump
See first post
Tim
suzolla
Postby suzolla » Thu Aug 02, 2012 10:36 pm
Bump
See first post
Tim
Munks1
Postby Munks1 » Fri Aug 03, 2012 8:20 am
Hi Tim,
Those 80 series longfield wiper seals i bought off you are primo!
They wipe the ball clean as a baby butt. I cant see any sign of grease or water getting past these babys.
Thanks again.
Mike
suzolla
Postby suzolla » Fri Aug 03, 2012 9:50 am
Cool, thanks for the feedback, good to hear they are working well.
Getting a few more just in case others are interested.
Tim
bob_or_jim
Postby bob_or_jim » Mon Aug 06, 2012 1:06 pm
Hi Tim, can you update us on what stock you have left/coming in?
suzolla
Postby suzolla » Mon Aug 06, 2012 1:32 pm
Hi,
Pretty sure first post is upto date with what I have.
Is there anything else you think it would be worth while getting as I am putting together an order at the moment.
Tim
suzolla
Postby suzolla » Wed Aug 15, 2012 1:30 pm
Bump
See first post
Tim
suzolla
Postby suzolla » Mon Aug 27, 2012 5:36 pm
Bump
See first post
Tim
suzolla
Postby suzolla » Mon Sep 03, 2012 9:38 pm
Bump
See first post
Tim
suzolla
Postby suzolla » Mon Sep 17, 2012 10:24 am
Bump
See first post
Thank you
Tim
Return to “Axles Tyres and Wheels”
Users browsing this forum: No registered users and 21 guests
