Hilux and Landcruiser Front Axle Rebuild Parts
Moderator: Vendors
Hi,
As the title says i have got a few Trailgear Front Axle Rebuild Parts as listed below.
Toyota Solid Axle Spindle Brass Bushings $60 for the pair
Toyota Rock Ring Knuckle Felt Protectors $30 for both sides
Rock Ring Extended Stainless Button Head Bolt Kit $20 for both sides
Trail Gear Trail Safe Inner Axle Seals (Sold in Pairs) $25
Trail Safe Toyota Knuckle Ball Polyurethane Wiper Seals and Rock Rings $85 for both sides
Aisin FWH Hub Outer Dial O-Rings $25 for both sides
LONGFIELD TOYOTA KNUCKLE LIFETIME WIPER SEALS Set of 2 $70
Toyota 54mm Wheel Bearing Nut Spindle Socket $25
Hilux Wheel Bearing Inner Grease Seal, also required when doing the IFS Hub Swap.
Plus postage which on most items would only be about $5-$6
PM me if interested
Cheer
Tim
PM me if interested
Cheer
Tim
http://www.4wdstuff.co.nz
80 Series 1HDT Auto 2" Lift 33's running on Transformer Oil Road Truck
80 Series 1HDT Man Std at the moment, Plans to modify for Off Road
Re: Hilux and Landcruiser Front Axle Rebuild Parts
Bump,
See first post
Tim
See first post
Tim
suzolla wrote:Hi,
Toyota Solid Axle Spindle Brass Bushings $50 for the pair
Trail Safe Toyota Knuckle Ball Polyurethane Wiper Seals and Rock Rings $95 for both sides
PM me if interested
Cheer
Tim
Hi Tim is there a website that I can go to look at this stuff. just been on the trailgear site and couldnt find anything.
Hi, most of it is Trailgear stuff but all over the place.
I will put some photos up hopefully tonight
Tim
Tim
Will try and do tonight, camera went flat
Tim
Tim
Hi,
Have put some photos up of the various parts
PM me if interested
Tim
PM me if interested
Tim
Hi,
PM me if interested
Tim
PM me if interested
Tim
Bump
See first post.
PM me if interested
Tim
See first post.
PM me if interested
Tim
Bump
See first post
PM me if interested.
Tim
See first post
Tim
Bump
See first post
Tim
See first post
Tim
Bump,
See first post.
PM me if interested
Tim
See first post.
PM me if interested
Tim
Bump,
See first post.
PM me if interested
Tim
See first post.
PM me if interested
Tim
Bump,
See first post.
PM me if interested
Tim
See first post.
PM me if interested
Tim
Bump,
See first post.
PM me if interested
Tim
See first post.
PM me if interested
Tim
Bump,
See first post.
PM me if interested
Tim
Only 2 sockets left
See first post.
PM me if interested
Tim
Only 2 sockets left
Bump,
See first post.
PM me if interested
Tim
Only 2 sockets left
See first post.
PM me if interested
Tim
Only 2 sockets left
Bump,
See first post.
PM me if interested
Tim
See first post.
PM me if interested
Tim
Bump,
See first post.
PM me if interested
Tim
See first post.
PM me if interested
Tim
Bump,
See first post.
PM me if interested
Tim
See first post.
PM me if interested
Tim
Bump
See first post
Tim
See first post
Tim
Bump
See first post
Tim
See first post
Tim
Bump
See first post
Tim
See first post
Tim
Hi Tim,
Those 80 series longfield wiper seals i bought off you are primo!
They wipe the ball clean as a baby butt. I cant see any sign of grease or water getting past these babys.
Thanks again.
Mike
Thanks again.
Mike
Cool, thanks for the feedback, good to hear they are working well.
Getting a few more just in case others are interested.
Tim
Tim
- bob_or_jim
Hi Tim, can you update us on what stock you have left/coming in?
Hi,
Pretty sure first post is upto date with what I have.
Is there anything else you think it would be worth while getting as I am putting together an order at the moment.
Tim
Tim
Bump
See first post
Tim
See first post
Tim
Bump
See first post
Tim
See first post
Tim
Bump
See first post
Tim
See first post
Tim
Bump
See first post
Thank you
Tim
See first post
Thank you
Tim
