Rock solid Diff armour
Moderator: Vendors
- tomsoffroad
- Flopsie
I've made a couple of these, can make more if needed.
Solid as, 10mm thick.
These ones suit an 8" Toyota diff. They can be sorted to suit most diffs tho.
Pretty much bullet proof
$82 +gst +freight
$130 +gst fitted. Painted, with new diff oil.
$82 +gst +freight
- ClassicCruiserSpares
- Sausage Shack
Re: Rock solid Diff armour
tomsoffroad wrote:I've made a couple of these, can make more if needed.
$82 +gst +freight
They look familier
- tomsoffroad
- Flopsie
Imitation is the greatest form of flattery
Hey how much for one of these posted to hobart 7140 for a 93 surf ?
- tomsoffroad
- Flopsie
Hobart? As in Tasmania? Do you want one for the rear diff on your surf?
yep thats the hobart he's in
Yeah mate 7140 yeah surf 93 model
- tomsoffroad
- Flopsie
Ok cool. I'll suss out freight on tuesday
Did he want it fitted with new diff oil Tom??
how do these bolt of cause i can not see any holes ?
- Sausage Shack
in4rhvn wrote:how do these bolt of cause i can not see any holes ?
There made to be welded straight to the housing.
oh yeah do u make other body prtection like tranny or sump covers ?
- tomsoffroad
- Flopsie
Mainly do bar work but can build most things. Much easier to do if I have the vehicle here tho Chances are pretty good that I can find a 130 surf to build stuff on then send it to you.
You've probably already found this?
http://www.offroadexpress.co.nz/Forums/ ... 67&t=27391
Cheers Tom
yeah well ill get one of these first and then get onto you for some more parts find out how much postage is please cheers
- tomsoffroad
- Flopsie
I whipped up another couple of these (one was destined for Tasmania, but no contact ) Anyone want one?
Sorry i have not been in contact i have been very busy. i will get in contact with you when i want one should be soon
Users browsing this forum: No registered users and 17 guests
