80 Series Leading Arm , LJ and KZJ Trailing Arm Bushes F/S
Moderator: Vendors
Hi,
Have just got some Genuine Toyota suspension bushes.
Got some 48702-60050 which are listed as 80 series front arm bushes. Can do these for $55 each incl post
Also some 48702-60060 which are listed as rear arm bushes for post 1990 KZJ's and LJ's Can do these for $65 each incl post NONE LEFT AT THE MOMENT, any interest for anymore
They appear to be the same except the 80 Series front ones have 2 small holes in the rubber on each side.
Much cheaper than the $150 to $200 each I was quoted by Toyota.
Not sure why the 80 Series are $10 cheaper.
Only got 8 of each to see if there is any interest.
PM me if interested.
Tim
Tim
- IcedJohnno
- Trailer Trash
Re: 80 Series Leading Arm , LJ and KZJ Trailing Arm Bushes F
Great service, thanks Tim.
If I had not replaced my rears with Nissan ones, I would be keen. Those nasty Whaa-Ping ones from SAS were less than useful. I will contact you when the front end goes.
Thats great Tim...
If you can hold a set of four 48702-60060 till mid august. I am in....
Need to replace the shocks on my car !...
Please advise....
Please advise....
Hi Calvin,
Yes all good will put your name on them, just let me know when you are ready, do you have the same issues with your front ones.
Tim
Tim
suzolla wrote:Hi Calvin,
Tim
No just put two new arms in after bending one at monstr's 24 hour challenge last Easter... My wof man noticed my rears were chopping out again....
He will fail me on my next one if they are not seen to.
Suz do you still have 4 rear 70 series bushes?
Hi,
Yes still got 4 of the 70 Series
If you want them PM me
Tim
Tim
Lawrence, will be posting yours tomorrow.
Have still got some 80 series leading arm ones left, none of the LJ KZJ trailing arm ones (yes Calvin have still got yours)
Is there any other interest in the LJ KZJ trailing arm ones to see if it is worth getting any more, need to get a few as the shipping cost is a killer.
Tim
Tim
Any chance u have any front panhard bushes for a kzj78? Cheers
Hi, sorry no panhard bushes, have you priced Toyota ones or alternatives.
Could possibly get some if they are expensive here.
Tim
Tim
do you have any ln130 surf rear lower arm bushes?
cheers andy
cheers andy
Hi Andy,
No sorry, not sure if you can buy them separately, have you tried Toyota, did they give you a part number, if you have part number can see what I can do.
Tim
Tim
Hi,
Any interest in
80 Series Leading arm bushes, axle end or chassis end
80 Series rear suspension bushes.
LJ and KZJ Trailing arm axle end bushes,
Looking at getting some more
Tim
Any interest in
Tim
Are they the same as the Nissan ones?
https://www.mountshop.co.nz/shopdisplay ... tem=28H005
I need to replace my crappy mountshop ones that only lasted 6000kms.
Look very similar from what I remember of the dimensions, will check tonight.
The 80 series front are virtually the same as the LJ rear except for the 4 tiny holes in the rubber as shown in the pictures and they are $10 cheaper than LJ.
Same price as the Mount shop pre GST price.
Tim
Tim
Hi,
Yes they appear to be the same as the Nissan ones, all sizes the same except I mesured the OD as about 60.3mm, I would think the MountShop sizes are just round numbers so would say they are the same
PM me if interested. Only got the 80 series ones unless Calvin can wait a couple of weeks.
Tim
Tim
Bump
See first post
Tim
See first post
Tim
Bump
See first post
Tim
See first post
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Hi Tim I may be interested in front and rear for my 80 series landcruiser. Do you still have enough left? I can confirm this with you by Thursday cheers Nathan.
Hi Nathan,
Still got front 80 Series, don't have any rear sorry.
Tim
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Tim, would be keen on a full rear set for 80 series.
Are you able to help. Cheers bob
Hi Bob,
Sorry about the slow reply, missed this one.
Don't have any rear ones sorry, are you still looking for some and if so how soon do you need them.
Thanks
Tim
Thanks
Tim
Bump,
See first post,
Only got 4 of the 80 series ones left.
Thank you
Tim
See first post,
Thank you
Tim
Only 2 of the 80 series left at the moment
Tim
Tim
not in a real hurry, only for winch truck.
if you can get some just let me know.
thanks Tim
thanks Tim
Hi,
Getting some more bushes and also so 80 series rear suspension ones, will be similar cost.
Also getting some 80 series front knuckle spindles, genuine toyota, will be less than what they are advertised on TMe for non genuine ones.
Worn spindles is often the cause of loose wheel bearings.
PM me if interested,
Tim
Tim
i will pm and take set of rear 80 series bushes.
thanks Tim
thanks Tim
Users browsing this forum: No registered users and 11 guests
