Well, probably first of many really
Since the throttle is controlled via the injector pump, why is there a diaphram operated butterfly just before the inlet manifold?
Question for Diesel gurus - TD27T
Re: Question for Diesel gurus - TD27T
egr. some guys take it out and put a bolt through it. I just too the butterfly out of it
I took mine out completely and used steel putty to fill the holes
I still run mine, combined with a bov It doesn't seem to slow it down any....
So, I can get rid of the butterfly valve in there? and do away with the hose going to that diaphram?
I may as well remove the hose going to the EGR valve to, and stop that opening?
I removed my thottle body looking thing and replaced it one i made out of some 6mm plate and 63mm pipe. Makes for better air flow and less leaks.
Users browsing this forum: No registered users and 18 guests
