12 volt compressor
klompy
12 volt compressor
Postby klompy » Thu Dec 27, 2012 7:53 pm
Hi what is a good brand compressor to buy,will be used on 35"tyres.
rob-mu
Re: 12 volt compressor
Postby rob-mu » Thu Dec 27, 2012 9:02 pm
Arb or convert your air conditioning pump
andrew007
Postby andrew007 » Thu Dec 27, 2012 9:30 pm
4wdbits.co.nz 8)
Nis-man
Postby Nis-man » Thu Dec 27, 2012 9:50 pm
I got myself a Terrain Tamer one, it is quite big and does the job well on my 35's.
klompy
Postby klompy » Fri Dec 28, 2012 6:34 am
Was that the typhoon model Nis-man.
rokhound
Postby rokhound » Fri Dec 28, 2012 6:53 am
I wouldn't waste my time with any of the electric ones on tyres above 33". Convert the a/c pump or put another one on. To do a 35" tyre you need (imo) to have a reserve of stored air so it has had some time to cool down, and if you are going to have a tank why not use a compressor that can fill it effectively?
4WDbits
Postby 4WDbits » Fri Dec 28, 2012 9:55 am
Depends what you want.
If you want to pump up 35s from 10psi to 40psi in a minute or 2 then you really need a descent compressor, regardless of whether a tank is used or not (because the compressor will be going pretty much full time while pumping up the tyres). There is limited choices, ARB twin motor, Boss Imagehttp://www.4wdbits.co.nz/ProductDetails.aspx?productID=4283 or Extremeaire Imagehttp://www.4wdbits.co.nz/ProductDetails.aspx?productID=4188.
For something truely portable you want this Image http://www.4wdbits.co.nz/ProductDetails.aspx?productID=4130 or the Magnum version Imagehttp://www.4wdbits.co.nz/ProductDetails.aspx?productID=4307.
The other end of the scale is spending 30 minutes pumping the tyres up with a cheapy Imagehttp://www.4wdbits.co.nz/ProductDetails.aspx?productID=573
klompy
Postby klompy » Fri Dec 28, 2012 3:24 pm
Thanks for the info guys,I didn't realise top of the the line compressors were so expensive,may look at a dive bottle or I'll be calling 4WDbits.
tallsam66
Postby tallsam66 » Fri Dec 28, 2012 3:56 pm
For a top end ARB (twin motor & compressor ) youll be looking at about $900 plus tank cost, manifold & installing it ....but they are real good ....you get what ya pay for !!!
rokhound
Postby rokhound » Fri Dec 28, 2012 4:11 pm
As a comparison, I just bought an elcheapo 95ltr compressor from Supercheap. Stripped off the 240v motor and air compressor, hooked up the wiring to the feed for the aircon compressor and fitted air line and high temp hose in between as required.
Compressor $145
Misc bits $150
Can run air tools and sorts out my 40" tyres from 5psi to 30psi (although I have not timed it, estimate about 1.5 - 2 mins a tyre).
klompy
Postby klompy » Fri Dec 28, 2012 5:20 pm
Yeah rok I know air con pumps go hard but I want to keep my air con and if I could fit any thing else around the motor I would.
Nis-man
Postby Nis-man » Fri Dec 28, 2012 8:52 pm
Hi Klompy
Mine just has Terrain Tamer on it, I have not had an issue with it, from memory it was on special for approx $250.00. It has a maxium 150 psi and does 160L/min.
It takes a little while but not too long, normally just pump up my 35's while I am havn a chat with the lads. It is definetly quicker than the smaller options.
SamLogan
Postby SamLogan » Wed Jan 16, 2013 8:14 am
I have just got around to installing my arb twin motor compressor. They are rated to roughly 170 lpm free flow which is more than any other 12v compressor on the market. Haven't got around to pumping up tyres yet but when I do I will let you guys know. They run rattle guns happily. Only 700 from Pete Munroe in chch. Would have liked an sanden on york but I don't have enough room under the bonnet as I am not getting rid of my ac.
Sam
Return to “Tool Shed”
