Tomsoffroad & Customs
Moderator: Vendors
- tomsoffroad
- Flopsie
Re: Tomsoffroad & Customs
Intercooler brackets on a Safari. Forgot to get pics of the drivers side
I like the shroud that came out very cool, the ramped corners will add alot of strength
Nice work
Nice work
- tomsoffroad
- Flopsie
De-Ranged wrote:I like the shroud that came out very cool, the ramped corners will add alot of strength
Nice work
Cheer man
tomsoffroad wrote:Intercooler brackets on a Safari. Forgot to get pics of the drivers side
Is there a custom inlet manifold hiding under there? More of your work?
Tom is a man of many hidden talents...has fabbed up quite a bit of stuff for me and has improved on aftermarket suppliers gear .
Modified inlet manifold came from UFI in Perth.
- tomsoffroad
- Flopsie
Twodiffs wrote:Tom is a man of many hidden talents...has fabbed up quite a bit of stuff for me and has improved on aftermarket suppliers gear .
Cheers Jamie
I have access to a nice alloy pulse mig now and would be really keen to have a go at modifying an inlet manifold........ actually I thing ill do one on the Cruiser And anyone else whose keen
- tomsoffroad
- Flopsie
Another airbox, snorkel package. K&N does the cleaning
1uz in a YN65 Hilux. 3" airbox to throttle body, 3.5" snorkel. Sounds mean under throttle
- tomsoffroad
- Flopsie
- tomsoffroad
- Flopsie
Hey Tom, where did you get the 3.5" bends from..? for the snorkel.. Been thinking of doing similar.. to get the extra 10 or so hp out of mine.. also main reason is I have to go 6 point cage and need to move my snorkel..
Noice!! Thats exactly what i've been getting at..plenty of room between the airbox and filter which is what the zd30 box lacks!
Don't what Tom does for bends but I just bought a 3.5" donut from Chase exhaust.
http://www.chase.co.nz/part/528/0/DN89X177
Roughly $120 from memory.
Twodiffs wrote:Noice!! Thats exactly what i've been getting at..plenty of room between the airbox and filter which is what the zd30 box lacks!
yep its quite good.
tho i wonder with the spare room behind the box if he could have used a flat panel filter.
- tomsoffroad
- Flopsie
Big wrote:Hey Tom, where did you get the 3.5" bends from..? for the snorkel.. Been thinking of doing similar.. to get the extra 10 or so hp out of mine.. also main reason is I have to go 6 point cage and need to move my snorkel..
Chase. They're in chch and sell everything exhaust
- tomsoffroad
- Flopsie
tweake wrote:Twodiffs wrote:Noice!! Thats exactly what i've been getting at..plenty of room between the airbox and filter which is what the zd30 box lacks!
yep its quite good.
Definitely thought about it. Still havent got my head round how to makes it work. Thinking if I was to keep the lexan lid I'd have to make the box 2 piece to clamp the panel filter. .... or maybe clamp the panel filter with the lid
tomsoffroad wrote:Definitely thought about it. Still havent got my head round how to makes it work. Thinking if I was to keep the lexan lid I'd have to make the box 2 piece to clamp the panel filter. .... or maybe clamp the panel filter with the lid
either way.
two piece like factory setup with clamp half way down the 'box'. window on top.
or make the lid as an insert to clamp the filter and fasten it at the top.
hey I'm after a new front bar for my 95 hilux and winch. I'm wanting to get one in this photo? did you make this one or can you produce the same thanks
- tomsoffroad
- Flopsie
sv6lux wrote:hey I'm after a new front bar for my 95 hilux and winch. I'm wanting to get one in this photo? did you make this one or can you produce the same thanks
Nope that's not one of mine. No problems making one similar tho
- tomsoffroad
- Flopsie
Finally got Robs radiator shroud finished.
That's pretty sexy my boy.
- tomsoffroad
- Flopsie
rokhound wrote:That's pretty sexy my boy.
thanks dad
- tomsoffroad
- Flopsie
Been building bars Finally installed the Prados shroud. Pretty stoked with how it turned out
FK mee.. how big is that radiator..? I mean thick.. 10 core..lol need to know eh..
- tomsoffroad
- Flopsie
Big wrote:FK mee.. how big is that radiator..? I mean thick.. 10 core..lol need to know eh..
Its intercooler cored custom made. Bout 100mm thick. Monstrous
Hey mate...keen to get some pricing to do a 2" lift and snorkel supplied and fitted for a '96 3.0 diesel Surf.
Or is it simply easier to just phone?
- tomsoffroad
- Flopsie
Bit more on the Pajero
Hi Tom. Awesome work mate. Am building up a ln106 with lexus v8 at the moment. Are you doing anymore of those beadlock rings as would be interested in a set myself. Cheers Sam
- tomsoffroad
- Flopsie
Time for an update.
My first Suzuki Vitara diff swap on this little beasty. Apart from the mounts everything is factory Vitara
- tomsoffroad
- Flopsie
Then got back onto the Prado. It needed a brace between the coilover struts. So in true redneck fashion I got carried away There simply wasn't enough room under the bonnet so.............................. I'll post pics of the bonnet tomorrow night when I've finished hacking
- catalystracing
Damn that's nice work, like the way you make it work, no matter the challenge.
Users browsing this forum: No registered users and 24 guests
