I got asked to make up a couple of these so I thought I'd make 6!!
3 are now sold and I have 3 left.
$70+freight each. Get them while they last
D21 Terrano steering idler arm braces FOR SALE
Moderator: Vendors
- tomsoffroad
- Flopsie
Re: D21 Terrano steering idler arm braces FOR SALE
Thanks, I couldn't make them for that. I will drop you an email and get some payment details
Ian
Ian
- tomsoffroad
- Flopsie
Only 2 left now
- tomsoffroad
- Flopsie
Shyte Tom you must be rolling in it now..
- tomsoffroad
- Flopsie
Big wrote:Shyte Tom you must be rolling in it now..
at $70 each???? Hahaha sounds like a tui ad
- tomsoffroad
- Flopsie
Going to make another batch of these tomorrow if anyone wants one.
$70 + freight
$70 + freight
Good product for those wanting to keep the traditional bushed idler arm and will definitely stop it bending.
Just a heads up, there were 2x different types of idler used in the WD21 with very slightly different mounting bolt hole locations. May pay to leave the three mounting holes for the customer to drill?
Although, Sometimes its confusing because the shaft may already be bent very slightly (invisible to the eye), throwing off the mounting hole location again. Even worn out bushes are enough throw it off. So it may be safer to install a new idler arm while you're at it.
- tomsoffroad
- Flopsie
lax2wlg wrote:Good product for those wanting to keep the traditional bushed idler arm and will definitely stop it bending.
True BNT reakons theres only one. I might give Repco a call and check part numbers. I use a brand new idler arm as a jig.
- stovanovich
Any more of these left Tom?
Had to change my Idler Arm yesterday after the long weekend so I think I'd better have one.
Te Rino
"Hubs In, Caps Off"
"Hubs In, Caps Off"
- Stropper
Any more off theres going to be made ill be keen for one
Should fit D22 too Tom, I remember getting one off 4WD1 for my old D22.
- tomsoffroad
- Flopsie
Yes I can make more no worries. There $120incl gst tho, not $70 anymore sorry, that was jus to get rid of a batch I made
Not sure if they fit a D22. Is the idler arm the same as a d21?
Users browsing this forum: No registered users and 21 guests
