Tomsoffroad & Customs
Moderator: Vendors
- tomsoffroad
- Flopsie
- tomsoffroad
- Flopsie
Re: Tomsoffroad & Customs
Lovely work Tom. Jealous......
whats the score on the tabs ontop of the lower mounts ..... another set of shocks or sway bar ?
- tomsoffroad
- Flopsie
De-Ranged wrote:whats the score on the tabs ontop of the lower mounts ..... another set of shocks or sway bar ?
Swaybar
Hi Tom,
Looking good, couple of questions
What bushes are you using
Are the top and bottom links the same length and are they parallel to each other.
Any touching of the Tie rod on the bottom links at full flex
whoops that was 3 questions
Tim
Tim
- tomsoffroad
- Flopsie
suzolla wrote:Hi Tom,
Tim
Bushes are 130 surf
top arms are 610mm. Lower arms are 700mm and aren't parallel.
No touching but at full flex and full lock there would only be 1mm clearance max.
Its all pretty tight in there Tim. I wondered several times if using prado knuckles and ln106 steering arms would've been easier. Then by setting up the tie rod and drag link like on a 60 series cruiser the tie rod would then be in front of the diff. Food for thought.
tomsoffroad wrote: I wondered several times if using prado knuckles and ln106 steering arms would've been easier. Then by setting up the tie rod and drag link like on a 60 series cruiser the tie rod would then be in front of the diff. Food for thought.
At least that is an easy(ish) thing to change in the future if it becomes an issue.
As always, nice work bro.
- tomsoffroad
- Flopsie
shortylux wrote:tomsoffroad wrote: I wondered several times if using prado knuckles and ln106 steering arms would've been easier. Then by setting up the tie rod and drag link like on a 60 series cruiser the tie rod would then be in front of the diff. Food for thought.
Thank you
There's no issue with this one bro. Just thinking out loud for the next one
Hi Tom,
Thanks for the info, looking to do mine sometime but will see if cert man will accept single top link.
Sounds like it is well designed if no touches, good stuff.
Tim
Tim
- tomsoffroad
- Flopsie
Tim
Was a mission Tim you shouldn't have any problems with a single top link, ive sent a few through cert now. Seems that as long as the top link is on the diff head theres no issues.
if that builder boy now with a bowtie uses that magnificent piece of engernering to out drive my nissan ill shout him a 24 pack and cook him breaky.hahahaha nice work tom turbo soooooon ??? or should i ask him
- tomsoffroad
- Flopsie
mike barnett wrote:if that builder boy now with a bowtie uses that magnificent piece of engernering to out drive my nissan ill shout him a 24 pack and cook him breaky.hahahaha nice work tom turbo soooooon ??? or should i ask him
Haa lets not go there Mike
Turbo is always a good idea
- Bush Crasher
Time will tell Mike! You going to Westport with this lot? Nig
Off to Perth next month Nig...want me to bring you back a UFI jobbie?
- tomsoffroad
- Flopsie
Update time Just finished Adams LN106 Tube(ish) deck.
It has a underdeck winch, Hi-lift and spade mounts and a under deck box for strops etc.
This is where we started
Winch mount (haven't added the actual winch mounts in this pic )
Whipped up some chunky guards
- tomsoffroad
- Flopsie
Then onto the cage
Then add the pretty black paint......... job done
- catalystracing
When I grow up I wanna be like Tom
The rear lights really set it off nicely
Super nice work mate
That is awesome. Looks like a wicked truck.
Thanks for ya help today
- tomsoffroad
- Flopsie
Another update........ another LN106 Hilux rears up front conversion with a kzn165 rear leaf swap. Oh and sliders Ended up with some pretty sweet flex for leaves
- tomsoffroad
- Flopsie
Then I got back onto the x brace on the Prado........ Before you ask ..... 1. Yes it unbolts. 2.The centre hole is above the radiator filler cap.
looks sweet man was wondering what u were going to do with that rather large hole in the bonnet
- tomsoffroad
- Flopsie
nztimr33 wrote:looks sweet man was wondering what u were going to do with that rather large hole in the bonnet
Cheers I try to do things differently
have you got the full leaf pack in the rear of that lux? Looks to be close to the bump stops. Mine is a bit short, was thinking of taking out one of the overloads but not sure which one.
Pete
Pete
- tomsoffroad
- Flopsie
Petemcc wrote:have you got the full leaf pack in the rear of that lux? Looks to be close to the bump stops. Mine is a bit short, was thinking of taking out one of the overloads but not sure which one.
Pete
yeah it is a full pack Pete. All the weight on the back probably helped
yea might have to try it with the fire wood on tomorrow haha.
Also have you got any pics of your front shackles? Do you put a support brace in them to stop them twisting like with the back ones?
- tomsoffroad
- Flopsie
Petemcc wrote:yea might have to try it with the fire wood on tomorrow haha.
No theres no barce in the front shackles. They're only 40mm longer than factory and there is no clearance for a brace.
Have yours twisted Pete?
That is pretty mean flex for leaves for sure !! Like it
Users browsing this forum: No registered users and 34 guests
