We have Amada extreme external bump stops on special for $400 a pair this week !!
A must if you plan on flying through the sky !!!
Amada extreme 3" travel external bump stops
Moderator: Vendors
Re: Amada extreme 3" travel external bump stops
Only 3" sizing available at this price ?!
specs? support and parts backup? warentteez..? you know I will thrash them.. and need to know if they are up to it..
1 year warrantee , we have all the nitrogen gassing gear and motul oils on site for rebuilds and also have rebuild kits coming for all our exo resivior shocks and competition stuff next order ,
warrantee does not include you forgetting to bolt them in and have them fall out on highway or lost in bush scenarios !!
specs? sizing?
Hi mate
Total length is 355 extended 275 compressed
52mm body , 20mm shaft , They are fully rebuildable and you can change the compression and reboung valving internally ,
are the 4"bumpstops same price.. and can you get them?
Hi mate I put an order for them last time but they are still on back order , I'm hoping I can get them for this tie around though !
okie dokie.. as I am looking at getting some 4" and depending when they turn up I was looking at the FOA ones.. shortly but seeing as these are new how would they compare to FOA ? as I have been wanting some for ages now and will be able to get some soon.. As you know.. our trucks are built on shoe string budgets.. so price performance comes into play when deciding.. ETA ? Keep me posted.. Ta
Don't know your numbers Big, but alot of the guys in the North Is found that 4" was too long. A lot are running the FOA 4" x 2.5" but are running them shorted to 2.5" or 3" of travel.
Problem was the bumps being used to much and as such were over heating I think. Ie they were basically acting as a second shock rather than a bump.
I have built my truck using the FOA and plan to run them at 3" travel.
If I could have purchased 3" bumps that would have been perfect. Would just save me the job of shortening the travel.
That's my 2 cents based on a little experience and a bit of listening.
Thnx Shorty.. I was wondering that myself as I have seen the long 4" like basically doing as you said BUT I was like it must be how they run.. I don't want them to fail because of overuse.. i.e. like another shock.. I just want for the hard impacts and to soke the bumps.. interesting.. cheers Maybe I need the 3"ones..
3" ones you say !
Looks like it.. how long does this "special" last as I need to get paid yet.. been 2 months..lol
End of the month of joy
Users browsing this forum: No registered users and 18 guests
