Show us your Nissan
Re: Show us your Nissan
cheers fella its pretty shiney by my standards...
and new must get it dirty and pinstripe it some
- Driver/Navigator
slidenyo wrote:
new truck td42t safari granroad limited,
has later model gu wheels 17's (someone wants them?)
centre muffler removed, chrome shit trap drip rail moldings removed.
roof rack applied from behind the shed.
flexs like a factory rig with swaybars still connected etc
Like the roof rack. I see it fits in the rails rather than needing cross bars. Where did you get it from?
- 92 safari 17
Sold the white patrol, brought this ute about 5 months ago, made some changes still a long way to go
roof rack was from the local scrappies,
I'm a bit of a dumprat so I pick the odd bit up of use at times,
I'd had that stored for 3 years before I got the safari with the intention of one day owning one
Sick of blowing rear hilux diffs so upgraded to Nissan, way stronger but added about 30kgs to overall weight.
- Newbie
94 Pathfinder..
- 2"suspension lift
- Safari snorkel
- High-lift jack
- 33x10.5" Simex Extreme trekkers
- 9500lb winch
- 2"suspension lift
- Safari snorkel
- High-lift jack
- 9500lb winch
The new truck got it for $600 I have started changing parts over
3" suspension kit in just needs the body lift
- Driver/Navigator
Was told it had a 50mm lift?
pretty std, got the EGT and boost gauge
tweaked pump and boost turned up to about 1 bar
EGR is removed,and so is the boost relief valve thing!
got the run of the mill 15" rims with 31"
also two electric fans running of a adjustable temp switch
will be setting up a top mount in the next couple weeks and MAYBY a turbo that can boost abit more
other then that its my daily driver so cant do tooo much
- Driver/Navigator
Well I have recently got this wonderful toy. Non turbo td42 swb. Got the PTO winch which I am super happy with. Some bar work I made, not super strong but protective. Running on kumhos but putting 32in comforsers on in march. Fairly standard. Happy to have an LSD in the back. No significant mods, I use it more often than I fix it and hope to keep it that way. Used to have a surf. Carrying a spare half shaft got old quick, replacing it every 2nd or 3rd time I went out. Solid axle is better for me until I get real money to do an ifs properly, maybe never haha
hang some bars along the sides its wider than the surf ,mine has to many dents from being not used to the width of of it,
like the mirrors nice design ,
- Driver/Navigator
Yeah side bars are the next on the list. Uni student so doing on the real cheap.
two days to no job fitter welder , looking to do bar work at home
- Driver/Navigator
My very standard D21
31x10.5xR15 KL71s
1st Plans
Snorkel
Alloy bash plate
New radiator
Aux trans cooler
Body Lift
After that ill want more power - intercooler + boost + fuel
31x10.5xR15 KL71s
1st Plans
Snorkel
Alloy bash plate
New radiator
Aux trans cooler
Body Lift
- kiwibronco
- Driver/Navigator
My Trusty GQ "Rosie. Getting a bit tired and ready for a makeover but one of the most reliable and versatile vehicles I've ever had. Definately earnt some TLC which is comin in the next few months with a rebuild.
My MK Nissan Safari with lots of mods - currently for sale as have bought a GU Patrol
- Stropper
- Stropper
DIRTBIKE23 wrote:terrano wd21 td27NA
- Rex Calibvr
- Driver/Navigator
Also have the white one in profile pic, 87' navara, 3.8 going into that.
This one is 1990
Also have a Mistral for sale, 2.7 turbo diesel, auto
Listed here
This one is 1990
Listed here
- Stropper
