hilux inner guard trimming
Petemcc
Postby Petemcc » Wed Mar 18, 2015 7:37 pm
Any body got photos? New feet are going to rub at the back of the inner guard on the front below the accelerator. Time for a trim!
Also rear of cab is close but might be ok. Anyone trimmed that?
Pete
Big
Re: hilux inner guard trimming
Postby Big » Wed Mar 18, 2015 7:51 pm
just get a grinda and cut to your hearts desire.. :wink: it just a shitty lux.. :lol:
Petemcc
Postby Petemcc » Wed Mar 18, 2015 7:55 pm
Yea but I don't want my foot to go though the hole in the floor haha the cutting is the easy bit!
NJV6
Postby NJV6 » Wed Mar 18, 2015 9:34 pm
What size shoes have you got on it now Pete?
derk
Postby derk » Wed Mar 18, 2015 9:55 pm
can you redrill the perches and sneak the axle forward bit :D
Big
Postby Big » Wed Mar 18, 2015 10:10 pm
I think 37's.. :shock:
Ashohman
Postby Ashohman » Thu Mar 19, 2015 7:52 am
Also intrested in this as my 35s rub in this area.
Petemcc
Postby Petemcc » Thu Mar 19, 2015 9:52 am
yep 37 creepys. Still not 100% sure if I will keep them. Got them cheap enough so can always sell them again. Either way I will still keep my other tyres for normal stuff. If I do keep them they will be off road only.
Axle is already moved forward about as far as it will go
shortylux
Postby shortylux » Thu Mar 19, 2015 11:15 am
I have no photos but on my RN36 I cut the flat section out of the floor just in front of the body mount. Then cut a few slits in to the firewall (the bit that would be behind the accelerator pedal) pushed it back and welded it back together, adding some panel steel where needed. It's not uncommon to get a bit of rust around the body mounts so easy to pass it off as a rust repair.
Reading that back to myself I suspect it is no help at all.
Good luck.
tomsoffroad
Flopsie
Postby tomsoffroad » Thu Mar 19, 2015 2:46 pm
I have pics bro of one I did....... but they're on the laptop. Ill post them tonight :D
Ashohman
Postby Ashohman » Thu Mar 19, 2015 2:59 pm
Sounds good
juz
Postby juz » Thu Mar 19, 2015 6:04 pm
BFH! :lol:
Mehrts
Postby Mehrts » Thu Mar 19, 2015 6:08 pm
Don't go too hard with the hammer! I gave the back of my front guards a bit of a bash to help make some room, and then I quickly found out that I couldn't get full throttle because I'd gone in too far! So I just took the hammer to the inside of the cab and went the opposite way for a bit! :roll:
Toyhatsu Bitsalux
tomsoffroad
Flopsie
Postby tomsoffroad » Thu Mar 19, 2015 7:04 pm
Mehrts wrote:Don't go too hard with the hammer! I gave the back of my front guards a bit of a bash to help make some room, and then I quickly found out that I couldn't get full throttle because I'd gone in too far! So I just took the hammer to the inside of the cab and went the opposite way for a bit! :roll:
Or just bend the pedal up a bit :wink:
Mehrts
Postby Mehrts » Thu Mar 19, 2015 7:05 pm
Haha yea, or that!
Toyhatsu Bitsalux
tomsoffroad
Flopsie
Postby tomsoffroad » Thu Mar 19, 2015 7:44 pm
Oh don't I feel like a dick! I cant find the pics :cry:
Basically I hacked a big hole from the kick panel round into the firewall - cardboard template - 1.2mm EG - zap zap - paint - done :mrgreen:
Petemcc
Postby Petemcc » Thu Mar 19, 2015 8:10 pm
Found it! https://m.facebook.com/permalink.php?st ... 3073880566
Googled hilux inner guard trim haha
tomsoffroad
Flopsie
Postby tomsoffroad » Thu Mar 19, 2015 8:31 pm
Haha nice work :D
Petemcc
Postby Petemcc » Thu Mar 19, 2015 8:56 pm
so is it legal? considering i already have my cert and dont really want to get a new one for it. Also tyres will be off road only (only certed for 15x8 and 35s/33s)
Pretty similar to a rust repair isn't it?
tomsoffroad
Flopsie
Postby tomsoffroad » Fri Mar 20, 2015 6:24 am
Should be fine. Bit of mud and wear and tear..... :mrgreen:
Return to “Toyota”
Users browsing this forum: No registered users and 11 guests
