another terrano/safari project = terrari
passengerpete
Re: another terrano/safari project = terrari
Postby passengerpete » Tue Nov 17, 2015 10:18 pm
lax2wlg wrote:Looks f@@@n cool Pete.
What does she weigh in at now with the Safari gearbox and front axle and bars/winch etc? A touch under 3 tonnes?
fully loaded up with camping gear, tents, bbq, spear 20l diesel, recovery ect, I drove it on the truck scales in Ranfurly and she came in at 2530kg. at a guess would be 100kg less without all the crap in it. at the same time a sas surf, lwb prado, swb prado weighted in too, all within 80kg of each other. only exception was a low roof lwb safari 2870g. from memory stock weight when weighted at rubbish dump was 1900ish kg
lax2wlg
Postby lax2wlg » Tue Nov 17, 2015 11:13 pm
Shit that's not bad all. I thought the 4 doors were a good amount over 2t standard.
I got my 3dr down to 1700kg loaded once, but after the bigger gearbox and rear axle and front diff, it climbed up to almost 2t.
Shit I think I can shave off the best part of 100kg by going back to the 8" rear axle.
danielbeek
Postby danielbeek » Wed Jan 13, 2016 12:38 pm
Amazing work on this truck. Very inspirational!
Just wondering, did you manage to fit that Subaru W2A intercooler without a body lift? Do you recall how tall it is?
Cheers, Dan.
ChurchurDan
Postby ChurchurDan » Wed Jan 13, 2016 12:55 pm
I put a subby water to air on mine without body lift but the under bonnet insulation has polished it.
passengerpete
Postby passengerpete » Wed Jan 13, 2016 5:07 pm
yea can fit a Subaru it in with out a body lift, in hind site should have gone air to air front mount from the start tho,
fh2014
Postby fh2014 » Wed Jan 13, 2016 8:31 pm
ive had front and top mount, and with the front mount in now, i dont think ill ever go back
r50terrano
Newbie
Newbie
Postby r50terrano » Wed Jan 27, 2016 6:57 pm
hey guys
so lets get this straight, a td42 will bolt on if you make new housing and use a TD27 clutch and pressure plate?
do you have measurements for the new housing you made?
passengerpete
Postby passengerpete » Thu Jan 28, 2016 5:51 am
r50terrano wrote:hey guys
anything will bolt on if ya make if fit. so yea if ya make a bell housing then yea it will bolt on. one easy step eh,
I used the stock flywheel and upgraded std clutch only because that's what I had, there's no reason why ya cant use something else that's the same spline.
poss682
Postby poss682 » Thu Jan 28, 2016 4:39 pm
Hi Pete
do you have any videos of this in action?
r50terrano
Newbie
Newbie
Postby r50terrano » Thu Jan 28, 2016 9:08 pm
sweet thanks, I'm doing some work on my r50 at the moment, 25psi boost water to air intercooler 12mm pump etc and have been looking at a jeep diff but a td42 box and diff sound like the go
passengerpete
Postby passengerpete » Thu Jan 28, 2016 9:37 pm
poss682 wrote:Hi Pete
sorry mate nothing worth showing might put it on the to do list tho.
Checkerhead
Postby Checkerhead » Thu Jan 28, 2016 11:49 pm
Take my gopro with you on Waitangi weekend.
passengerpete
Postby passengerpete » Mon Feb 08, 2016 6:15 pm
lax2wlg
Postby lax2wlg » Mon Feb 08, 2016 6:53 pm
passengerpete
Postby passengerpete » Mon Feb 15, 2016 4:12 pm
getting a wee stretch just sorting new shocks any one know anything off the shelf 900mm open and 490 closed ?
[url]Image[/url]
still a bit more left in it, but tyre is about 10mm from hitting body so this will do
Checkerhead
Postby Checkerhead » Mon Feb 15, 2016 11:37 pm
I suspect you wont get anything for those dimensions. You are looking for big travel/closed length ratio. You'll have to compromise on one of those measurements.
900-490 = 410 travel.
410/490 is 84%.
As an example a 125mm lift efs extreme for the rear of an 80 series is 695 open, 400 closed, therefore 295 travel. 295/400 is 74%.
But I guess as the travel gets longer the travel/closed length ratio will get bigger. So maybe you'll find what you need.
Checkerhead
Postby Checkerhead » Mon Feb 15, 2016 11:46 pm
Also you just effectively asked for a shock with over 16" of travel. That's no small ask.
Maybe these?
http://www.4wdbits.co.nz/ProductDetails ... uctID=1511
(just run them as a shock, not as a coil over).
passengerpete
Postby passengerpete » Thu Jun 30, 2016 8:45 pm
shocks sorted ish
[url]Image[/url]
Clint
Postby Clint » Fri Jul 01, 2016 8:56 am
Nice flex! What shocks did you end up with?
Clint
UZJ71 Landcruiser
KTM 640
fh2014
Postby fh2014 » Fri Jul 01, 2016 2:15 pm
second that . thats some nice flex
passengerpete
Postby passengerpete » Mon Jul 04, 2016 8:51 pm
Clint wrote:Nice flex! What shocks did you end up with?
Clint
ended up with some rancho xl just because they cheep and had the size I needed part no rs999012
also moved shock mounts all over the place can add some pic if want.
passengerpete
Postby passengerpete » Sat Apr 07, 2018 5:27 pm
the old girl still going. but very beaten up its been extremely reliable. I should up date this abit some day.
