hi iv got an Isuzu Mu 2.8T, the turbo is screaming and I know its fucked.
How easy is it to remove the turbo all together and just have a straight 2.8. I don't really need a turbo, I realise itl be gutless but its just a work hack so any advice?
I do have a replacement turbo to go in but which is easier replacing or removing???
As the turbo can cause more issues then not having one is this right?
dan
1993 Isuzu Mu 2.8 turbo removal
Re: 1993 Isuzu Mu 2.8 turbo removal
If you have a spare to go in, just replace it, its going to be less work than converting it
drinking hatorgade
I havent done 1 on an isuzu before but how easy is it to take off then put back on?
as with any light duty diesel 4wd they are a bit of a cnut but if you get in a day or two before and crc everything your going to undo it will make it easier as with using the right tools
drinking hatorgade
Users browsing this forum: No registered users and 16 guests
