jumpy tach
fish
jumpy tach
Postby fish » Mon Oct 31, 2016 6:16 pm
Hey fellas has anyone experienced a jumpy tachometer needle?
Its in my rodeo wich is an isuzu really, it goes up when i turn to the left and down when i turn right, so its affected by gravity somehow and most of the time sits about 2.5 regardless of actual rpm, its annoying me!
Pj_Marsh
Re: jumpy tach
Postby Pj_Marsh » Mon Oct 31, 2016 6:19 pm
Sounds like the cable is loose
fish
Re: jumpy tach
Postby fish » Mon Oct 31, 2016 8:51 pm
i had a poke around but couldnt figure out where the sensor is,
sirLachlan
Re: jumpy tach
Postby sirLachlan » Mon Oct 31, 2016 11:58 pm
Want to swap ? mine is 500 rpm for engine tuning aND 1500 when I toot the horn . Ha ha
Electronic in a ln106 tho
MihiT
Re: jumpy tach
Postby MihiT » Tue Nov 01, 2016 5:40 am
Unless there's a known solution for the vehicle, my general advice would be to pull the cluster and re-solder all the connections on the daughterboard. Check for wires around the steering column that are pulling, pinching or rubbing.
Re: jumpy tach
Postby skid » Tue Nov 01, 2016 1:46 pm
my 80 series used to do that as well, then one day it just stopped working
speedo cable had snapped
sirLachlan
Re: jumpy tach
Postby sirLachlan » Tue Nov 01, 2016 2:07 pm
The tacho was jumpy coz the speedo cable snapped ??
nzlux
Re: jumpy tach
Postby nzlux » Tue Nov 01, 2016 2:46 pm
MihiT wrote:Unless there's a known solution for the vehicle, my general advice would be to pull the cluster and re-solder all the connections on the daughterboard. Check for wires around the steering column that are pulling, pinching or rubbing.
That is how if fixed faulty tachs in my pajero and hilux
Return to “Isuzu”
Users browsing this forum: No registered users and 21 guests
