Not starting
privitepiles
Not starting
Postby privitepiles » Sun Apr 23, 2017 4:30 pm
Hey haven't been here for ages but my 92 v6 bighorn wont start it has spark and fuel but nothing happens does any one have any ideas on what I should check next thanks heaps
fh2014
Re: Not starting
Postby fh2014 » Sun Apr 23, 2017 7:34 pm
unless it dropped its piston rings overnight, you dont have fuel or spark - at least not at the right time anyway.
are these motors efi or carburetted?
check/charge up battery first - a tired battery might not start it.
distributor cap got water in it?
fuel pump actually pumping fuel to the injector rails? my moneys on fuel pump.
EFI fuse gone?
HV leads shorting out?
derk
Re: Not starting
Postby derk » Mon Apr 24, 2017 3:45 pm
did you check the fuel delivery with a noid light or some other method, have you tested fuel pressure at the rail/injectors?
1bad4x
Re: Not starting
Postby 1bad4x » Sun Oct 29, 2017 5:05 pm
Could be the same issue I just had on daughters MU.
See if the P or N is illuminated. If not. Very likely its this... viewtopic.php?f=29&t=47210
Good luck
Return to “Isuzu”
