Hey, I am hoping that someone can help me out.
I'm for looking replacement driveshaft bolts for a 94 gen 2 Surf (VZN130) - driveshaft to front diff
Can anyone point me in the direction of a supplier (Auckland) or should I just be going through Toyota?
So far I have tried The Bolt Shop and Steelmasters
Replacement Driveshaft Bolts
94 Gen 2, VZN130 Surf, 2" Lift, 31" Micky T's
Re: Replacement Driveshaft Bolts
tried the wreckers?
Toyotaz Galore told me that they just crack them then bin them and I haven't tried any others yet.
That being said though I was hoping to get new ones
Now this isn't in any way a gripe against Toyota but just as a heads up to anyone else looking for new replacement driveshaft (Propshaft) nuts, bolts & spring washers.
If you do get them from Toyota, you will be looking at $9.27 for each nut, $4.92 for each bolt and $6.71 for a pack of 4 washers.
That being said, I'm assuming that it will be much the same for Nissan and the rest of the manufacturers so it really is a bugger that it seems that you can't get an alternative from anywhere else.
- mudlva
Try don kyatts hobbile ave manukau
Always a good idea to use the correct spec fastener, but...
The grade 10.9 cap screws holding on my front driveshaft were obtained for a few cents each from the local engineers supplies outfit & have been happily joining together a low range geared V8 & a couple of 36" Simexs for a few km now without issue. Spring washers and lashings of red loctite for the win.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Cap screws and nordlock washers for the win
