95 24 valve vx
95 24 valve vx
What diff oils to use and how many litres per diff roughly? And what is the easiest way to refill trans oil? Cant seem to find a bung.. also which oil and how much for this?
Beer is not the answer... beer is the question, yes is the answer
Re: 95 24 valve vx
To find out what to use and how much, I use this:
https://www.penriteoil.com.au/product-selector
Select your vehicle and they will tell you exactly what you need. SuperCheap regularly have 40-60% off Penrite oils too.
I have a 92 manual , so cant help with the filler location
Who knew Prados could fly?
Re: 95 24 valve vx
Off hand it was just shy of 3L for the rear dif and 2L for the front. But could use different oils in each one if you have LSD rear, or Lockers. Not sure about the filler for the gearbox but some go through the dip stick tube.
Can also compare to the castrol site for quantities and recommended oil types.
http://www.datateck.com.au/lube/CastrolRetailNzl/
92 LWB Safari TD42
