KZJ78 Transfer case wanted
Gardengnome
Truck Hore
Postby Gardengnome » Fri May 10, 2019 9:16 pm
Hi all,
I'm in need of a transfer case for an auto KZJ78. I'm not sure if the manual and auto have the same transfer cases.
Preferably in Canterbury if possible but would consider all options.
Cheers, Phil.
Smurf
Re: KZJ78 Transfer case wanted
Postby Smurf » Fri May 10, 2019 9:24 pm
I still have my old transfer case from old LJ78. Jumps out of low box.
Any use to you
Gardengnome
Truck Hore
Postby Gardengnome » Fri May 10, 2019 9:39 pm
Cheers, Keith. I'll see, Fairly sure the transfer input bearing has gone in mine. Had Rose drive it while up on axle stands and horrible noises emanated from the transfer on the left directly behind the transmission.
Local would be good to get the truck ready for Queen's b-day weekend.
I'll let you know. Thanks for your offer.
Smurf
Postby Smurf » Fri May 10, 2019 9:45 pm
Oh bugger.
Gary Weaver, 0274557746 He isn't far from you. Marshlands Area. Was wrecking and selling Prado parts.
Gardengnome
Truck Hore
Postby Gardengnome » Mon May 13, 2019 12:46 pm
Follow up post,
Cheers for the contact Keith.
I have scored one over the weekend.
