okay be warned i haven´t finished yet hopefully that will happen next weekend but that depends on if my welder is available
so today i started taking things apart and getting things ready to do the cutting and welding
first things first remove the spring need a spring compressor umm haven´t got one handy oh well how about this
i´m not at all dodgy
then i looked at the perch and the body and thought if i lift the body up it should make the job alot easier
i just had to work out how to lift it up a little away from the chassis that towball will do it
redneck bodylift don´t worry it is only temporary
and see now heaps of room to get a grinder and welder in there
and here is the bit that will be going in to replace it
so hopefully next weekend i will have more to report
so wopass what are you up to next weekend
the mudcedes spring perches finally
my 4wd is not a truck
i couldn´t wait made a start on it tonight
so i decided to do a bit more on my wagen tonight all was going well until there was a bit of arcy stuff and a cloud of smoke bugger
serves me right for buying a cheap grinder
woohoo all welded in place now
started out all ground ready for the new bit
welded in place
painted matt black of course
reassembled
i decided to cut one of the old ones up and see what it looked like inside
not the best
woohoo so it is all good and back on it´s own wheels again
just got a couple of rust holes to fix in the body now and it should be ready for a WOF
welded in place
reassembled
not the best
- Sadam_Husain
- Angry bird
- Sadam_Husain
- Angry bird
niblik wrote:top stuff merc.. and ya got the insta-bling onto it too...!
whats next for the g wagon?
after i fix the 2 rust holes i have to deal with then i will look at the turbo diesel engine swap and the hydraulic winch that is all i have on the list at the moment
woohoo a little more to report got the mudcedes back from the panelbeater today no rust holes in the body now yay
just got to reassemble it which is my plan for the weekend and then i should be able to get a warrant next week woohoo
Users browsing this forum: No registered users and 56 guests
