Clearing up the confusion on radios....
4wdnuts
Postby 4wdnuts » Wed Nov 21, 2007 9:53 pm
There seems to be a lot of talk on here at the moment about radios and all sorts of other related things. so ive decided to write up a bit of an explaination to help all those out there that need it.
C.B Radio
These are considered the "old style" of radio and have been around for years. They are commonly used by trucks and by 4wd clubs etc. they operate on a frequency roughly around the 26/27mhz range. most vehicle mounted units put out 5 watts and this translates into a range from anywhere from 1km all the way up to 50km or more.
PRS/UHF Radio
these radios are relativly new. they are more commonly used in 4wd clubs and a lot of other places as well. these radios operate on a frequency around 476/ 477 mhz. most vehicle mounted ones are also 5 watts but ranges are generally less than the older cb. however they are alot clearer than the older cb's. allthough with the use of a repeater, range can be extended onwards of 150kms!
handheld units can also be brought but generally have alot less power. some as low as .5 watts!. these can be good if moving from a vehicle of for talking someone through a tricky section. although you can get handheld units that have 5 watts of transmit power as well.
so as you can see from the frequencies listed above, the two different styles of radio cannot communicate to each other. So you ask, which one do i buy? :? it really depends on what everyone else has and what your club uses. most people these days lean towards the PRS/ UHF units, however some do still use the CB Radio. If you still cant decide then Uniden do make a unit that has both styles intergrated into one!
So what to look for buying a radio?
for a vehicle mounted one, consider things like where can i mount it? does it have 5watts of transmit power? does it have a scan function? and also little things like what side the mike plugs into etc.
for handhelds the most important thing is probably the transmit power. its probably best to get one that has as much power as you budget allows. other things to think about are how long will it last on batteries? does it matter if i drop it in the mud?( obviously a cheaper one would be a better option here :lol: ) is it easy to use (ie big buttons).
so what does all that jargon mean on the box?
Scan: searches through all the channels and stops on them if they are active.
Duplex: this allows the use of repeaters. this extends the range considerably of your radio. if you are in canterbury then have a listen one night on channel 1. you will hear alot of people talking. if you push "dup" button then you can make use of the repeater and your transmission will be broadcast out as far as Darfeild, Oxford and Amberley.
CTCSS/ DSC: this is basically a tone that is sent with your transmission. it allows other radios that have this tone turned on to hear what you are saying. its usefull if you only want selected people to hear what you are saying.
Aerials:
you must get an aerial for the right frequency you radio produces. ie, you cant use an aerial designed for cb with a prs unit and vise versa. there are a few different styles of aerial like steel and fibreglass. some people have different opinions on whats better but at the end of the day, as long as its designed for the radio you are using then it should be fine.
also have a think about where your going to mount it. ideally the top of the roof is the best place but for 4wding this is really un practical. usually youll see them mounted to the bull bar, on the guard or on the back of the truck. think about what sort of track etc you go on. do you go driving close to trees that could easily rip it off (99% of us do)? also i would recommend the use of a spring to allow the aerial to bend down in case it does get tangled up in something.
when running the coax (aerial cable), try to keep it away from alternators, starter motors or other big electrical things. they can all interfear with the signal and give really poor performance of your radio. also make sure no sharp metal bits cut into the cable when passing through the firewall into the cab.
i think thats about me for tonight. if anyone can think of anything else that can be added then please add to this topic.
TJ
Postby TJ » Wed Nov 21, 2007 10:05 pm
Great work and explnation. Just to add, old school CBs (27 Mhz units) are also referred to as AM CBs. PRS is also referred to as FM radiio. I am not going to get into too much detail, but these kinds of units are incompatible with each other.
Handheld PRSs can be something from .5 watt to 5 watts.
NJV6
Postby NJV6 » Wed Nov 21, 2007 10:13 pm
Can ya go back to your post and make it a 'sticky'? Bloody good post & it'd be a shame to see it disappear off the radar. :cheers:
Bubba
Postby Bubba » Thu Nov 22, 2007 8:20 am
Bloody Good Post 4Nutts :lol:
this should even be posted up as a article so it can be referred to at any time, coz you know the same questions are going to be asked again and again amd again :roll:
Just one question on the scan function. I take it someone would have to be talking as the radio went past that freq for it to be picked up aye? Now I wrote it it seems like a silly question :oops:
Benjamin Franklin
Swaney
Postby Swaney » Thu Nov 22, 2007 1:04 pm
Great post.
Thanks for the info. After reading this I have decided I am going to be purchasing some Midland GXT850VP4's 2-ways off the net.
4wdnuts
Postby 4wdnuts » Thu Nov 22, 2007 6:15 pm
Bubba wrote: Just one question on the scan function. I take it someone would have to be talking as the radio went past that freq for it to be picked up aye? Now I wrote it it seems like a silly question :oops:
yes thats right. the channel has to be active. ie some one talking or transmitting on that channel
kruzin
Postby kruzin » Sat Nov 24, 2007 7:46 am
Good stuff mate. 8) . You have written here about PRS and CB, but what about VHS? Dosnt anyone use these? Because it would be really handy to have one that can get emergency services, forecasts, AND, be able to talk to everyone..
4wdnuts
Postby 4wdnuts » Sat Nov 24, 2007 2:00 pm
kruzin wrote:Good stuff mate. 8) . You have written here about PRS and CB, but what about VHS? Dosnt anyone use these? Because it would be really handy to have one that can get emergency services, forecasts, AND, be able to talk to everyone..
i have really only touched on the ones that we would use in the 4wd scene. however, i do know a few people that use vhf radios (myself included), but for the cost of decent ones and then all the nessecary licenceing etc, most poeple cant justify the cost.
In my honest opinion, you would be far better off hiring a mountain radio when you do your back country trips. if you ever need emergency services the channel is being monitored 24/7, and weather forecasts being transmitted every 12 hours (8am and 7.30pm from memory).
they are cheap to hire. i think around $25 a weekend but to purchase you would be looking at big $$$, but if your going to get the use out of it then it could be a well worth while purchase. 8)
kruzin
Postby kruzin » Sat Nov 24, 2007 4:23 pm
hireing a mountain radio is going to be the ticket then i think. Thanks alot mate!
callum007
Postby callum007 » Sat Nov 24, 2007 6:04 pm
Dace
Postby Dace » Mon Nov 26, 2007 7:32 pm
Has anyone ever bought these of trademe, are they any good?
http://www.trademe.co.nz/Browse/Listing.aspx?id=128492573
Swaney
Postby Swaney » Tue Nov 27, 2007 11:03 am
Is PRS (Public Radio Service) the same as FRS (Family Radio Service)?
Jon
Postby Jon » Mon Dec 24, 2007 3:40 pm
HF radio is also a good option and just a bit of usless information, if you belong to a Search and Rescue Team, You can use HF (for SAR use) (wink wink) without needing a license.
Keep the shiny side up.
giovanni
Postby giovanni » Mon Dec 24, 2007 8:20 pm
Quote:"HF radio is also a good option and just a bit of usless information, if you belong to a Search and Rescue Team, You can use HF (for SAR use) (wink wink) without needing a license."
That is once you have written permission from your SAR Police sergent,National Land SAR HQ and Radio Frequency Service,c/o MED.
With HF you get the distance at a price.
The radios are expensive and delicate.
Not very forgiving to water and vibration.
Use more battery power.
Large or very large antennas,2m plus in length are required,trees win!
Certain electro-atmospheric conditions,skip,permit you to work many hundreds of miles but not the stations you want,sub 80 miles,as an example.
"Make love to a Pantry owner.We need more of them!"
Jon
Postby Jon » Wed Dec 26, 2007 9:15 am
Yes well down here we are all of those so we don't have a problem. I do agree about the radios themselves not being up to our 4x4 environment. That's why my personal truck has UHF, AM 26 and 27mhz. That's all we really need around here. The HF is best suited as a base set like they are designed to be. :wink:
jdeburgh
Postby jdeburgh » Wed Dec 26, 2007 9:26 am
VHF although you can have more power output that PRS or CB is still only 'line of sight' communication. Chances are that if you are stuck somewhere you wont be able to contact them anyway because you are probably in mud (in a valley) or upside down at the bottom of one!
John
PS. I carry PRS, AM CB and my Amatuer radio VHF/UHF gear too...and a cellphone..or two..
-Vehicle: Rangie - 4 Wheels, 3 doors, Engine, Gearbox, other whirly bits, Steering wheel, Radio, Seats, Pedal that makes noise, pedal thats stops it, and pedal that helps stop the crunching noise when using the gear lever.
http://www.feilding4x4.org
Armz
Re: Clearing up the confusion on radios....
Postby Armz » Mon Sep 29, 2008 6:25 pm
Whats the advantages of having a in truck mounted prs instead of just a handheld? Im thinking its just a transmission thing, the bigger the aerial the more range you get?
Im thinking of buying one of these as you can unscrew the aerial http://www.trademe.co.nz/Electronics-photography/Radio-equipment/Amateur-radio/auction-178640375.htm then hard wiring in an aerial so when im in the truck I can screw it in2 that an use the car charger for the power. Then when I need to leave the truck I can screw in the normal aerial and have the best of both worlds, plus I get a 5watt prs a shit load cheaper than the DSE in truck ones.
Anyone got any thoughts on this idea? Have i missed anything?
Has any brought one of these?
Scarfies on the piss,
Postby coxsy » Mon Sep 29, 2008 7:50 pm
fweddy
Postby fweddy » Fri Oct 17, 2008 4:56 pm
Postby coxsy » Fri Oct 17, 2008 8:09 pm
yes to both 4wd action said they are good , the chassis may not handle hours of aussie corragations
fweddy
Postby fweddy » Thu Oct 30, 2008 5:03 pm
Two other options I'm considering
http://www.trademe.co.nz/Browse/Listing.aspx?id=185228654
http://www.trademe.co.nz/Browse/Listing.aspx?id=185230337
Opinions? the second one seems a good deal with the hand held included?
Are there better options? deals?
aroma
Postby aroma » Thu Oct 30, 2008 8:44 pm
Have just looked at the uhf article in the lastest 4wd australia mag in very basic language that i found easy to understand and compared three radios in vehicles and handhelds (sorry cant copy its at work) inc aerials
this isn't ment to offend any of the other comments on this subject placed by knowlageable people on this site
muskie
Postby muskie » Fri Jan 02, 2009 10:03 am
has anyone bought a uhf recently, any good package buys out there at the moment, i am looking to buy early 2009.
T-Boon
Postby T-Boon » Wed Mar 18, 2009 2:04 pm
Curious to know if these are any good ?
from 1-day,
Only one watt, but are $80 for two...
The Oricom PMR1000R 2-way radios are designed for activities that demand long-range capability.
With a massive 1 watt transmit power and a range up to 7km*, they deliver excellent long-range performance, making them ideal for serious outdoor enthusiasts and tradespeople.
The PMR1000R offers other must have features including 38 CTCSS codes, channel scan and hands-free capability. Compact, lightweight and rugged they come with a handy charging pod, rechargeable battery packs and belt clips.
Features:
2-Way UHF CB radio
38 license free channels
1 WATT of power
38 interference eliminator codes (CTCSS)
Range extender in duplex mode
Channel scan
Volume control
Roger beep tone
Channel busy indicator
Keypad lock
Nuisance delete
Backlit display
Call tone alert
Monitor mode
Hands-free use (VOX) (headset not supplied)
Headset jack
Specifications:
Range: Up to 7km (* Range depends on environmental conditions)
Frequencies: 476.425 – 477.400 MHz
Power: Ni-MH 4.8V 600mAh rechargeable battery pack (included, or 4 x AAA batteries (not included)
Charging time: Up to 14 hours
Model: PMR1000
Dimensions:
Radios: 150 x 55 x 32mm
Desktop charger: 190 x 75 x 55mm
Individual radio weight (with battery): 130g
Colour: Grey/black
Package includes:
2 x UHF radios
2 x belt clips
2 x Ni-MH rechargeable battery packs
1 x twin desktop charger
1 x AC adaptor
User manual
Thoughts ?
Note: Deal finishes Midday Thurs 19 March.
To Boon or not to Boon.
Postby coxsy » Wed Mar 18, 2009 3:39 pm
lets buy it, it will do till you have flat batteries then buy a big 5 watt truck mount
tgaguy1
Postby tgaguy1 » Wed Mar 18, 2009 5:52 pm
Buy them anyway. Most trips I go on I take my two hand helds as well as my truck mounted unit. If you have mobile comms available to you; you would be surprised how often you use it during recoveries and winching etc.
downunderxj
Postby downunderxj » Wed Mar 18, 2009 6:00 pm
I bought a pair last year from Dick Smith and have used them on the various club trips I have gone on. They go really well, I have had no issues.
Once on Odlins Road at the top of the Akatarawa's we were able to listen into a conversation between two people in Wanganui, going by the street directions they were talking about. A bit further than the 7 km, but I am sure there was some exceptional atmospheric conditions helping out.
Ian
'95 Jeep Cherokee (XJ)
1936 Ford Flathead V8 Colonial Cab (restoration project)
T-Boon
Postby T-Boon » Wed Mar 18, 2009 6:14 pm
yeah, might buy a pair, just for those times you want out of car comms. e.g recoveries and guiding cars.
sig
Jeep Jeep
Postby sig » Wed Mar 18, 2009 7:09 pm
i run a hand held as well as a vechicle one.when waiting in a line up off vechicles i normally walk up to the front to be nosey and if its a bit of a walk i,ll get the better half to drive the wagon up when its clear (i hate walking .if i cant drive or quadbike there it isn't worth going :D )
chrome
Postby chrome » Thu Jun 04, 2009 7:56 pm
why are people going away from am cb?? i just hooked up a uniden530 with arial for bugger all cost under a hundy
Users browsing this forum: No registered users and 11 guests
