Help needed. I’m about to be grounded when my WOF runs out due to a speedo failure.
Does anyone have an instrument cluster for the GQtd42. Years 1990-1994. With the yellow instrument markings.
Ill take one with faults if its the usual GQ faults of sticky movement or needs a tap to start. These faults can be fixed.
Phone or txt me 021 265 8878
Thanks guys
Need Instrument cluster for Safari GQ TD42.
1991 SWB GQY60 TD42 safari.
DTS turbo kit.
DTS turbo kit.
Re: Need Instrument cluster for Safari GQ TD42.
Hi Guys
I gave up in the end and took the cluster to Parrotts in Christchurch. Speedo issues solve by them fitting their custom speedo circuit board. There is a slight flicker but not an issue. It is adjustable, by them, to allow for different tyre sizes etc.
DTS turbo kit.
DTS turbo kit.
