WTB 2lte injector pump and housing that holds it to engine
as title say im after the injector pump and the housing that holds it as mine has broken the studs and slogged it's self out.
cameronmaxwell@xtra.co.nz
0274202727
0274202727
Re: WTB 2lte injector pump and housing that holds it to engi
got a pic of whats broken?
that housing is the front part of the engine. bit of a job to change it and you would have to find out IF you can get the gasket on its own. they usually come as a engine rebuild set ie includes head gasket etc.
its the lip that the injector pump sits into that has slogged out. hopefully should be able to get the gasket.
other option is to get it all off and get it built up and machined but i think that would cost more than to replace it with a 2nd hand one
0274202727
0274202727
Users browsing this forum: No registered users and 12 guests
