Got a few leftovers sitting in the shed for sale, thought I would see if anyone here was interested before I list on TM
SJ413 5 speed, unknown condition but was told it was good, input spins freely, shifts thru all the gears ok, only not using it as the engine I brought already has a box attached so will just drop the whole lot in in one go. $125
https://lh3.googleusercontent.com/-WYLAOAu1tOA/Uv1-OUobByI/AAAAAAAAAys/PjbxsCVgkq4/w1538-h865-no/DSC_0143.jpg
Brand new SU HIF6 (HIF44) carby, as popular for conversions on SJ413/G13A/G16A. Fitted with BCP needle and red spring from memory. No extra throttle brackets etc (Im going to order mine from the manufacturer once some of this stuff sells along with correct needle). Only selling as brought as a pair because the price was too good to refuse hence have one extra. $150 (retail around $550ea direct from manufacturer). Im not looking to make a profit just recover half what the pair cost me, previous owner brought for Rover V8 then changed mind on carb setup.
https://lh4.googleusercontent.com/-AF-h-MDWSfI/Uv1-RKBdVZI/AAAAAAAAAy4/9sI88OHkgsc/w1538-h865-no/DSC_0142.jpg
And a set of 4 black steel rims in 15x8 jap 6 stud, off beam axle hilux so I would guess -19 offset, average condition have been painted black from white so could use a repaint if you were fussy, but no dents etc. Selling as I kept these off my Hilux and will put the tyres on my Suzuki rims so Hilux rims no longer needed. $100
SJ413 Gearbox, SU Carb, 15x8 6 stud
Re: SJ413 Gearbox, SU Carb, 15x8 6 stud
can put up a pic of the rims please
Photo of rims:
https://lh4.googleusercontent.com/-KGvGEnNYJtI/Uv_01sMx_JI/AAAAAAAAAzM/0iBxpz0YU3M/w1538-h865-no/DSC_0144.jpg
Not really that bad, top left is the one with the worst paint for some reason, rest are ok. The only dent is the tiny little one just visable on the bottom right wheel just above the balance weight, certainly no big deal.
Tyres not included
Tyres not included
Also remembered I've got a Sj413 rwd sump and pickup spare if anyone wants one for a G16 swap, probably accept alcohol as payment for that
Mate I am keen on the Rims - I assume they are a standard Steelie rim that will fit a Safari?
Rims are SOLD. Everything else still up for grabs
Bit of a stretch... Any chance you still have the carb?
Sausager text me. I'm in Welly have a carb on my shelf.
0225197700
0225197700
DIRTY OLD HILUX
022 519 7700
022 519 7700
Users browsing this forum: No registered users and 25 guests
