Now that the Bodge is gone I have lots of surplus to requirements parts available.
Make an offer on the following [try to be realistic and I will too ]:
Pair Old Man Emu 764 Springs 220lb X 16.9" SOLD
Pair Genuine LR Springs purple/pink stripe approx 180lb X 17"
Pair Blue [Lovell Springs?] Unknown spec - Short, thick wire, minimal turns
Pair standard front shock turrets - fits Rangie/Disco/Defender
4 Koni Shocks - Standard [? Not sure I can measure them this weekend] Came off a D90 - these are quality kit and are in great cond. Fully rebuildable.
Steering damper
Pair 10 spline rear axles - Early Range Rover [this is your insurance package if you have a rear ARB] SOLD
Rover Parts
Rover Parts
The three position Lucas switch - Dim, Flicker and Off.http://home.off-road.com/~bodgerover/
Hey Bodge
I'm looking for a set of front springs to get the nose back up. Any of the ones you have good for a 2" lift?
Also keen on your axles (I wonder why!)
Drop me a PM with answers and the price you are after (remember realistic )and we can talk.
As for bagging rovers.........next you'll be driving a toymotor.
Rat
Rat
Rangerat - I had 764's in the front of my Rangie which were too hard in my opinion. I would try the LR 180's using this chart:
Aprox 1100 lbs per corner rear:
Aprox 880lbs per corner front.
----------Spring lt:---Lbs/inch----C:T/Load:--Installed Lth:--Bstop:
Rear-------17.8:-------320:--------1100:-------14.36:---------6.36:
Rear-------16.8:-------320:--------1100:-------13.36:---------5.36:
Rear-------17.8:-------270:--------1100:-------13.73:---------5.73:
Rear-------16.8:-------270:--------1100:-------12.73:---------4.73:
Rear-------18:---------220:--------1100:-------13.00:---------5.00:
Rear-------17:---------220:--------1100:-------12.00:---------4.00:
Rear-------17.2:-------180:--------1100:-------11.09:---------3.09:
Rear-------16.5:-------180:--------1100:-------10.39:---------2.39:
Front-------17:---------220:--------880:--------13.00:---------5.00:
Front-------16:---------220:--------880:--------12.00:---------4.00:
Front-------15.5:-------220:--------880:--------11.50:---------3.50:
Front-------17.2:-------180:--------880:--------12.31:---------4.31:
Front-------16.5:-------180:--------880:--------11.61:---------3.61:
Front-------15.9:-------180:--------880:--------11.01:---------3.01:
Note: Std RR has 3 degrees of castor angle, with B/stop clearannce of 2 inches.
Every HALF inch lifted, you will loose ONE degree Castor.
That should give you 1.5 - 2" lift and still be a smooth ride.
If you use the 764's you will definitely get the lift but will need a fair bit of weight up the front to compensate for the high lb rate. The Bodge had at least 3" at the front with bull bar winch and steering guard.
What do you have in there at the moment?
I will PM you about the prices...
at the moment I'm running heavy duty rear springs in the front (lbs/inch unknown)
Before the winch and twin batts went in this gave me a 2' lift and the castor angle went back to .5 degree's (which made it fairly sensitive, but not something I was concerned about)
Now with the added weight and the removal of 200kgs from the back I have got a nose down rake. (bump stop clearance was around 4.5")
the problem now may be that my rear springs are too long (they are the longest springs avialable from Rangie Spares, purple/orange) with an easy 6+" of bumpstop.
Add to the fact that I'm putting a 8274 in the front so add another 20kgs.
Rat
Rat
I had those long 18" rangie spares springs in the back of the Bodge only 180lbs which is too light for a full bodied rangie - with the 764's in the front the bodge was a little arse down.
I feel sure the 764's will hold up all your gear without a prob and net you some lift as well - they are a 'Medium Duty' rear which normally give 1.2" lift at the rear. With your relatively unloaded rear springs it may just level it all out...
Its your call.
I have PM'd you with some reasonable prices to make it worth your while...
Its your call.
RR Indicator Switch
Hi there,
I am looking for an Indicator Switch for my 1984 Range
Rover. It has a high and low beam, horn and indictor
functions. Can you help?
Much appreciated,
Karen
Please email: send2ren@clear.net.nz (I am waiting for the administrator to activate my account).
Much appreciated,
Karen
Sorry Karen no can do.
Try Tim Warburton at Bramble Downs on (09) 810 9894
He almost certainly will have one.
