Project PAJ (Kermit)
fullthrottle
Shuttle Queen
Postby fullthrottle » Sun Jul 17, 2022 8:30 am
Well!!!
Found my next project and collected it Saturday from Napier.
Nothing like a 4 hour drive back to Welly to find out what's wrong with it.
The bones are all there for a good little truck:
Lifted, 33's and engine swap for a 4D56T (all certified) WoF and Reg.
New Chromoly rear axles and bearings
New front CVs and bearings
It's had a few hands on it with some interesting ideas, but just cosmetic and nothing a bit of time won't fix.
So on the way back home, with about 60k's to go, lost the clutch. No fluid left in the reservoir.
And left rear axle seal might be gone as it's spewed some shit out across the tyre.
Will see what else needs tidying up. Then she'll be ship shape.
johnny262
Re: Project PAJ (Kermit)
Postby johnny262 » Tue Jul 19, 2022 7:06 pm
Very cool, fits right in parked on the main street of DVK lol
Will be watching with interest :D
MihiT
Postby MihiT » Sun Jul 24, 2022 6:58 am
Looks pretty tidy. Those engines benefit from deleting harmonic balance shaft, EGR, and adding turbo!
fullthrottle
Shuttle Queen
Postby fullthrottle » Mon Jul 25, 2022 12:17 pm
Ah, correction to my initial post. It is the turbo engine.
Was reading about the harmonic balance delete. What is the real benefit?
From what I have read, just removing the balance belt, would:
a) possibly increase engine vibration
but
b) reduce resistance for the motor
MihiT
Postby MihiT » Mon Jul 25, 2022 1:31 pm
fullthrottle wrote:Ah, correction to my initial post. It is the turbo engine.
but
That's pretty much the gist of it. Spins up quicker, uses less fuel. How much of each depends on more than that, but I reckon it's worth doing.
Everyone I've heard from had no problem with it gone, have heard a couple of stories of increased vibration (always a mate of a mate)
fullthrottle
Shuttle Queen
Postby fullthrottle » Wed Aug 03, 2022 7:43 am
Well have a bit of time now to come up with a shopping list to keep me out of trouble (aka: in the garage away from the annoying kids LoL)
(In no particular order)
1) Harmonic balancer delete
https://youtu.be/aDg91Vb_ods
2) Tuning old smokey. This seems a good place to start: https://delicaforum.com/index.php?threa ... power.707/
3) Build up some barwork
4) Fix leaking rear axle seal
5) Fix clutch ....tick...Just needed bleeding.
6) Clean up the wiring. It's had some interesting ideas.
7) Reconnect the gauges. EGT, Water temp. Wouldn't mind seeing if you can get the standard V6 Rev counter working with the 4D56. Must be some mod out there??
fullthrottle
Shuttle Queen
Postby fullthrottle » Sun Sep 11, 2022 7:16 am
Well, it's been a bit of a slow start.
Daughter's car had to come off the road for a bit and I had to rebuild the A pillar. (Bloody 90's Hondas)
Anyway, reinstall the last CV. Wheel bearings could do with some love. The grease has certainly seem some water. Have heard that those AVM manual hubs can let a bit of water in, so will explore the pros and cons of going back to fixed. The transfer system is a bit different to the 80, where I get a 2WD option. But the whole front drive train would still be spinning with hubs fixed.
Thought I would start off with a bit of a more detailed inspection.
Engine bay
Front diff oil looked like grey slime, transfer case had about a quarter left in it. Home-made air box seemed more like an oil transfer system with the amount of shit being recycled from the rocker cover. Will either put in a catch can or just extend the breather into the chassis (self anti rusting technique )
Airbox oil
Radiator is being pressurised and so slowly blowing water out the overflow. I reckon stuffed headgasket at the least, maybe head. Will plan on whipping this off when convenient.
Found some rust in the back right cover of the boot. Easy fix and will plate it back up. Removed the remaining carpet and all looks good.
Wiring for the motor is as tidy as my teenagers bedroom. Plus seem to be missing a number of controls in the cabin.
Check out that earth srap bro...
Wiring
Earth strap
Winch isn't running, Well not even wired in. WTF
Seems like someone was hungry and had a chew on the drivers seat.
So for a start I've flushed and replaced all the oils for diffs, transfer, Gbox, Engine. Actually runs a bit quieter now.
Whipped out the airbox and will replace that useless pod filter with one of those Ryco O2 Rush filters. (Better filtration and cleanable)
Filter
NJV6
Postby NJV6 » Fri Sep 16, 2022 9:08 pm
I vote go back to fixed flanges. less abilty to get water in that way, I had genuine AISIN ones and until I went back to solid flanges was doing wheel bearings every WOF, haven't done one now for about 5 years. I do carry one hub with me incase I break a CV on the track and can swap it for the flange. If you ever put an auto locker in the front you will need the free wheeling hubs though. Yes and No with the whole front drivetrain spinning, the front diff disconnect does mean the CV's are spinning but the crown wheel and pinion isn't, just the side gears do. There is no noticeable difference in fuel consumption with or without FWH.
Big
Postby Big » Mon Sep 26, 2022 10:45 am
interesting read, jkust out of curosity, how much boost are you running ? I have a very original std V44 which is a great runner and cheap on gas but it just lacks.. powa..lol its got all the fruity bits as std, intercooler etc so looking at pumping it up a bit :) cool truck btw
fullthrottle
Shuttle Queen
Postby fullthrottle » Mon Sep 26, 2022 11:15 am
According to the gauge, it's currently running 8psi. In the Delica forums they say the standard turbo and engine will handle 17psi. That is a massive step up for standard.
With the EGT, Boost and fuel I will just tweak it enough so it's running well with good temps.
It doesn't need to be a dragster LoL.
Plus I am sure the head gasket is stuffed, possibly head. So too much boost this side of looking at it closer, may result in something nasty :-)
fullthrottle
Shuttle Queen
Postby fullthrottle » Sun Oct 02, 2022 2:36 pm
Right, decided to tackle the wiring!! What a bloody birds nest! So annoying when people just twist the wires together and slap a bit of masking tape over it :shock:
Wiring
I've pulled almost all of the dash out to trace all the wiring. Since it had a 4D56T transplant, I needed to find some of the dodgy wiring and correct it. Looks like I need a new water temp gauge as the sensor wire goes no where.
There are two senders / sensors and from what I can work out, the one in the upper radiator hose housing is the gauge temp sensor (single pin) and the larger one (2 pins) in the head is for the glow plug temp sensor. (circled in RED)
Senders
LoL, that earth strap connection is a crack-up.
Anyway, I'll replace the sender unit to match the new VDO gauge.
Have pulled out all the redundant wiring and ordered some new power distribution/fuse boxes to clean everything up.
I've also been through and labelled all wiring that was added with the transplant.
Still more to do, getting there slowly.
Users browsing this forum: No registered users and 2 guests
