Porsche Off -- A Cayenne Offroad Project
1bad4x
Re: Porsche Off -- A Cayenne Offroad Project
Postby 1bad4x » Sun Nov 18, 2018 5:01 pm
mudlva wrote:Wire the isolater into the low amp side of the control box. The low amp side has a perminate pos that feeds the forward reverse switches. Break into that small cable ran switch.
Heavy winching will melt those switches.
Just remember that the switch will only shit itself under loading... and thats exactly when you want reliability ah.
Nice hiding spot as well
Bugger... That was my post fitting fear, It is quite easy to access the back of the switch where I can join the cable on one post if it does blow mid recovery. but if that is waist deep in muddy water easy assess would still suc!
I am not worried about it destroying the switch as long as the power is permanent.. When I got it my thinking was they are used for race cars as main battery shut off so will easy handle starter motor, what I didn't consider until I completed the fitting was the time factor when under load, as a starter is heavy for a short time.. Winching tends to be more load & Long periods.. when I do the pre-tension I will keep a real close eye on the switch temp, still wont be quite the same as a full loaded recovery...
1bad4x
Postby 1bad4x » Mon Nov 26, 2018 2:52 pm
Nothing to exciting this weekend, just added some graphics
I was a bit cheeky & copied from some online photos was still quite the mission to get the art work cleaned up so I could make them..
1bad4x
Postby 1bad4x » Sat Dec 01, 2018 2:53 pm
Made a start on the roof rack/box today, only done the cutting, dam the notching is a PITA with just hand tools.... thank god for flap discs...
Just about ready to start stitching it together
1bad4x
Postby 1bad4x » Tue Dec 11, 2018 11:10 am
Crazy busy time of the year, but still made some progress on the roof tray.
BlakeNZ
Postby BlakeNZ » Tue Dec 11, 2018 7:26 pm
how did you do the "porsche" lettering?
1bad4x
Postby 1bad4x » Tue Dec 11, 2018 10:08 pm
BlakeNZ wrote:how did you do the "porsche" lettering?
I do a little signwriting “voodoo signs” more a hobby/side line business. So I have a vinyl cutter at hme.
Comes in handy for bits like this.
1bad4x
Postby 1bad4x » Fri Dec 21, 2018 5:54 pm
So the roof rack is all sorted, Lights fitted & Wired. Took a slight diversion on the way home today, Hilux before me came out with a smashed rear window & dented tailgate. Porsche came out unscathed.
Crawlerer79
Postby Crawlerer79 » Sat Dec 22, 2018 4:45 pm
Looks awesome!!! Love it :mrgreen:
'Lando' - 1994 V8 Disco
1bad4x
Postby 1bad4x » Fri Jan 04, 2019 4:07 pm
Boxing day sale online! got 1/2 price Flomaster! Arrived super quick so got to installing...
Wanted to use factory tips & keep them in exactly the same spot so came up with this...
old muffler removed & new lined up with the original ends & brackets
All attached to the factory exhaust pipes
Sounds much better...
https://youtu.be/pAfripyJ1OM
wjw
Postby wjw » Sun Jan 13, 2019 4:35 pm
:D
Who knew Prados could fly?
Clint
Postby Clint » Tue Jan 15, 2019 9:34 am
Looks very cool! Top marks for some good fab work with a basic workshop 8) & great work actually getting it muddy!
Clint
UZJ71 Landcruiser
KTM 640
1bad4x
Postby 1bad4x » Wed Feb 13, 2019 4:46 pm
blacked out the chrome on the headlights, & had a little off road excursion the other day. not much mud around at the mo..
1bad4x
Postby 1bad4x » Fri Sep 13, 2019 4:45 pm
For a change I remembered to catch a few seconds footage while offroad. not the sort of off-roading we get to do often in NZ
its short & sweet but amazing I got any footage. & after this trip I didn't even have to wash the truck..
https://youtu.be/HQRKqu_s2XM
MATT4U
Postby MATT4U » Sun Oct 06, 2019 6:23 pm
Wow, it’s been a while since I have been on here let alone posted but this is cool!!!!
Users browsing this forum: Google [Bot] and 24 guests
