Cruiser/Prado chassis centers/ coils???
Does any one know if the Prado chassis rails are narrow in the front to allow for coils compared to a 1991 73 series cruiser with leaf springs?. I am thinking of going for coils in a MWB 1Hz cruiser. Reading a few posts,guys have gone for nissian or 80 series diffs etc .Just thinking aloud ... Cheers.
Re: Cruiser/Prado chassis centers/ coils???
Hi Mate, I've got the prado coil centre dimensions noted somewhere, will dig em up for you tonight. There may not be much in it as the chassis needs to be narrower to allow for the wheels to turn anyway, plus Nissan GQ or 80 series axles are a fair bit wider so you should have space to play with.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Cheers dude,will be interesting to see the difference,I don,t want to go with longer axles etc trying to stay with my diffs,axles to keep costs down may have to go bigger if chassis rails are smaller. Cheers for your reply.
I have some chassis dimensions on file somewhere for both trucks. Plus can measure my one as it's out in the open at present. Will have a dig later tonight when I get home from work.
ok here is the chassis dimensions
They don't really show the chassis width....I will measure my KZJ78 in the morning...
He is the one for a HZJ73
And now a LJ78 Prado
[/URL]
[/URL]
Thanks for the info,it will be great to see what your truck measures.Cheers.
For my KZJ78 Prado the dimension from the outside of the chassis frames at the coil perches is 730mm.
On a side note I will have some perches and drop boxes available from my old chassis when I cut it up sometime in the new year.
Will also save the panhard rod mounts too.
Hiya, 730mm same as mine,that means the Prado front axle etc is wider than my 73 series ,they must have done that so they can fit coils in. If you have the time can you measure your front assembly ? Does any one else know if the front axle is bigger or same as 80 series?. Thanks Calvin I would be keen on your parts when they become available. Cheers Colin.
What other dimensions do you need... As my whole truck is in bits so easy to measure... Throw up a list.
Hi just at this stage ,am I right in thinking the front axle etc is bigger than my 73 series?. Cheers.................
Just spent hrs looking for info,I think I have worked out the prado and my 73 cruiser share the same length axles ,so that means the prado uses a small front coil spring that fits in between tyre and chassis rail.. I take it that guys use 80 series axles etc so they can use bigger coil springs and stronger diffs ... .. Question is has any one used there 70 series diffs and gone coils?????.
Hi Colin Ski. I have a bare lj78 prado chassis on diffs if you want to come Have a lookskie measure up.
Cheers Clive
Cheers Clive
1001 ways to skin a cat mate but IMO I wouldn't want to put a smaller and relatively weaker diff and radius arms in the front of a heavy cruiser probably ok for a road truck but not for what they were built to do, personally I'd shove a safari axle under it or even better coil the axle you've already got in there you can cut all the shit off an 80 series or similar and weld it all on, plate the chassis and make a good wrap around gusseted mount for the panhard theres a fair bit of stress on the mount and have a good look around the front cross member while your at it they start getting a bit thin and start cracking with old age, rust and newly added stress
Cheers Clive,Amazing whats on your door step,,, with info from Calvin and other info from the net answered my question about Prado chassis sizes,cheers Derk , I certainly will go for the bigger diffs etc just need more info on fitting coils into existing diff???. Cheers all.
Users browsing this forum: No registered users and 34 guests
