1996 KZJ78 starting issue
Posted: Tue Mar 02, 2021 9:38 pm
hi all,
can´t believe the bad luck I am having with the truck.
just had everything welded up and repaired for inspection.
saturday morning I got in the truck and it started spot on after sitting weeks in the cold driveway, temps here in central Europe around zero at the moment.
just moved it out of the driveway to make room for work on the Delica and when I wanted to move it back in same day but 6 hrs later it would not start at all.
now the fact part:
glow plug light - not on at all, no current to glow plugs
engine check light - not on at all when turning ignition on, same as glow plug light
injection pump gets around 11V which I believe is ok from previous reads on previous problems?
but: injection pump does not get triggered.
the engine turns and turns but there is absolutely no fuel to injectors, no smoke at all nothing, just dry dead
I have now located the glow plug relay and starter relay, glow plug relay not powered.
where do I find the main relay that goes by no. 85915-60030? are there two of it? parts reference picture is showing two units but not exact location.
will have to take out second battery later to see if it is there in the left fender? like the other two relais are?
any guesses?
thanks
Peter
now the fact part:
any guesses?
thanks
Peter
