LJ Project "Rangi"
UBZ
LJ Project "Rangi"
Postby UBZ » Wed Sep 26, 2012 7:47 pm
So I needed something to beat around in the bush , something that I didn't need to care to much about the panel work .
So project "Rangi" was born
So word went out on the Local LJ network and a suitable LJ50 was acquired .
l
The Plan as it stands .
LJ50 Chassis / Tub (whats left of it) / Roll cage
LJ80 Diffs (spring perches moved to LJ50 Spacing)
SJ410 Transfer Case ( with aftermarket reduction gear set)
Suzuki F10a 970cc Engine and LJ80 4 speed gearbox.
Rear Mounted Radiator
Front and Rear disc breaks
Rear Lockright auto locker
9000lb winch (rear mounted)
7.50x16 SAT (32x7.5x16) mud tyres on modified factory 16" rims
I all ready have most of the parts , so hopefully this will progress quickly
the Bottom of the tub has the standard dipped in acid dissolving coke can action going on , has been "Rangi" repaired by pop rivitting some sheet metal in where the floors were and the rear has been chopped off .
Some of the more interesting features
The Origional LJ50 3cyl 2 stroke and gearbox, that is going to DB as spares .
Awesome super advanced ultra air cooled , fiddle break plumbing - these will be removed
The Plumber Snorkel
Rear Tray Removed
Engine Stripped out
LJ80 Axle and engine mount Donner. - Chassis has major rust issues
lincooln
Re: Suzuki LJ Project "Rangi"
Postby lincooln » Wed Sep 26, 2012 7:54 pm
looks like a cool project.
Lubrication Specialist
Lubrication Engineers
imsohi
Postby imsohi » Wed Sep 26, 2012 7:57 pm
awesome looking weapon should be some fun when your done
PuddleJumper
Postby PuddleJumper » Wed Sep 26, 2012 9:45 pm
Yay! Another LJ - Will be watching! 8)
DieselBoy
Postby DieselBoy » Wed Sep 26, 2012 9:53 pm
I worked out that LJ's been sitting in my shed for 5 years looking for a purpose in life!!!!
Wooot can't wait to see its reincarnation :mrgreen: :mrgreen: :mrgreen:
UBZ
Postby UBZ » Thu Sep 27, 2012 12:02 pm
DieselBoy wrote:I worked out that LJ's been sitting in my shed for 5 years looking for a purpose in life!!!!
only 5 years :lol: :lol:
Was definalty fun "driving" it around the paddock :lol:
LJ80 Donner front Diff - just a little green
will only be using the Housing , Diff head and Axles.
BlakeJ
Postby BlakeJ » Thu Sep 27, 2012 12:07 pm
oooo is this the kati kati or keri keri storage LJ from DB's shed, awesome to see it being fixed up
UBZ
Postby UBZ » Tue Oct 02, 2012 4:10 pm
BlakeJ wrote:oooo is this the kati kati or keri keri storage LJ from DB's shed, awesome to see it being fixed up
Yep its the Katikati LJ .
A little bit of progress
Got both the front and rear doner Diffs stripped down .
Rear Diff Housing is toast , so the LJ Network comes to the rescue again with a usable housing .
Front Diff Head is in Mint Condition .
Rear Diff Head is a bit dirty , but with a re-bulid will be fine as R&P are still sweet.
but Im proborby not going to use these diff heads know as im looking at putting 4.88 LJ50 R&P into 410 Carriers for better gearing .
One Front axle is going to need a sleeve where the seal runs
Rear axles look ok , just need new bearings .
mercutio
Postby mercutio » Tue Oct 02, 2012 5:29 pm
I have a spare F10A sitting around left over from my little Suzuki it is one of the SC100 coupe engines so apparently has an extra 2 HP due to factory head work. It needs the headgasket replacing and it has a set of bearings rings and gaskets with it.
UBZ i'll give you first refusal.
my 4wd is not a truck
jervisad
Postby jervisad » Wed Jan 09, 2013 11:16 pm
:lol: whens the next update on this thing it looks like it will be a mint little truck
UBZ
Postby UBZ » Thu Jan 10, 2013 8:24 am
alot going on. alot getting chopped n glued
Farkn broken welder till the weekend :evil: :evil:
zukmeista
Postby zukmeista » Thu Jan 10, 2013 8:34 am
:shock: If you are keen enough to be fixing that can you do the SJ410 too?! :D
UBZ
Postby UBZ » Thu Jan 10, 2013 9:28 am
zukmeista wrote::shock: If you are keen enough to be fixing that can you do the SJ410 too?! :D
Feeling rich are we :lol: :lol: At least 50hrs work in that ...........
I told you before , go buy a $300 mig welder and teach yourself to weld . Dosen't need to be pretty if you start learning on the bits that will be hidden.
Once you master welding zuk panel steel , everything else is easy.
DieselBoy
Postby DieselBoy » Thu Jan 10, 2013 9:35 am
UBZ wrote:Image
I see a super bling chassis and running gear under that!!!!
Priorities :D :D
Big-AL
Postby Big-AL » Thu Jan 10, 2013 10:36 am
UBZ wrote: Dosen't need to be pretty if you start learning on the bits that will be hidden.
Or the bits that get hit with a grinder after the weld :D
UBZ
Re: LJ Project "Rangi"
Postby UBZ » Mon Sep 30, 2013 8:48 am
Rangi is rolling on 4 wheels finally ......... :mrgreen:
Just a little bit of trimming of the body work required :roll: :lol:
Check out the pumpkin clearance :twisted: more clearance on 32's than a Hilux on 36's
zukmeista
Postby zukmeista » Mon Sep 30, 2013 12:29 pm
Those tyres look farking massive on it! :shock: This thing will kick arse offroad when you finish it. 8)
UBZ
Postby UBZ » Sun May 19, 2024 1:04 am
12 years later ……..
Rescue Mission on Armsup
mercutio
Postby mercutio » Fri Jun 21, 2024 11:06 pm
Nice one :mrgreen: :mrgreen:
DieselBoy
Postby DieselBoy » Thu Jul 18, 2024 10:25 pm
Wow, no like button. This is good, I need to actually write a comment :D :D
Awesome to see it move, now to get it across to the Sth Island :lol:
Return to “Suzuki”
Users browsing this forum: No registered users and 2 guests
