milky oil in escudo sump
Hi guys just pulled the sump of my 1990 escudo g16a and it had a little bit of milky looking oil in the front by dipstick and at the back on right hand side how do i tell if its buggered ?? Could it just be because its been sitting for over 6 months not being used and sitting outside in palmys weather??
Re: milky oil in escudo sump
compression test i spose, if they come up trumps it may be just 6 months of condesation or water in the breather pipe filler cap etc.
but generally if it's been sitting you'd have oil on water, not mixed so i say it was running with a leak.
thanks for your help will put it back together and do that test hope fully its all ok
Crash, I've done a compression test on a vehicle with a cracked block and it was within specs but a leakdown test showed a leak into the cooling system.
Stick it back together and if it uses coolant do a compression and leakdown test.
Users browsing this forum: No registered users and 30 guests
