Any Mitsi gurus here?
altair
Post by altair »
Okay, have a 1994 L200 4WD, V6 5 speed manual. Love it. But it is incredibly low geared, so just wondering if there is a bolt in diffhead which will raise gearing a bit? Do they share running gear with that era Pajero? Or is it an across the board diff? It pulls 3000 at 100, main problem is 1st gear etc is so low. Just wondering if anyone has any info? Thanks all.
Crash bandicoot
Re: Any Mitsi gurus here?
Post by Crash bandicoot »
I don't see why pajero diff heads are any different only major would be to get the 4.6's from a non superselect pajero as the front diff in a superselect engages differently to the l200's I suspect you have 4.9's or (4.88 to be exact) 4.6's will drop your rpms to 2800ish at 100kph and so on
Crash bandicoot
FYI pajero coil sprung so only internals interchangeable.
NJV6
Post by NJV6 »
Have a look under the bonnet and see what the build plate says on the line trans axle. It'll say something like V5MT1 4.875.
cornflake
Post by cornflake »
first gear low as in ur not going fast enough or what my l200 2.6 in 1st is about 20kph if that and sits at 3000 at 100 as far as it will let me go with out killing it
Return to “Mitsubishi”
