how do i find out the diff ratio of my bighorn its a 1990 2.8itd, the plan was to solid front end and put cruiser 4.1 diffs under it and soa now that iv picked up some 36" simex im thinking the diff ratio wont be right. do i keep the rear bighorn diff and find a front to match or change both diffs for something else?
Rich
project bighorn.diff issue
- Spring Free
Re: project bighorn.diff issue
I older isuzu's are 4.5 which match up to the toyota 4.5 diff
Isuzu Mu 3.1TD
Jack up the back wheels, count the number of prop shaft turns to one wheel turn (with both wheels up).
- Spring Free
sweet will do that tomorrow, do the front 4.5 diffs come out surfs or old hiluxs?gotta tryn find one now
muddyplumber wrote:sweet will do that tomorrow, do the front 4.5 diffs come out surfs or old hiluxs?gotta tryn find one now
It would be easier to just put hilux axles so you can 4.8 diffs so you will get your gearing back from running 36's
Isuzu Mu 3.1TD
Most of the 87-92 model bighorns are 4.31 diff ratio, though the R spec models in that range are 4.56.
- Spring Free
is the spec r model the one with really wide guards? bin told by someone that if it has the 4.5 ratio it should be ok, can you get crawler gears put in if needs be?
- rangimotors
Jezza wrote:muddyplumber wrote:sweet will do that tomorrow, do the front 4.5 diffs come out surfs or old hiluxs?gotta tryn find one now
X2
i think this is the best option, not because they are better and im certainly not saying you couldn't make it work with the other one. but you need to consider the future, and look at how many different ratios and options there are about for hilux diffs. they are everywhere and easy to pick up cheap if you decide to change ratio in the future or smash one.
Yes the R spec model model is the one with the wide guards.
I did hilux in the rear as i had to go hi pinion in the front ( 4.8HP) i soa'd my isuzu one before we relised this prob, oh mine was on a mu, mine on 33s atm still goes hard,
- Spring Free
took everyones advice, found 2 complete 4.8 ratio hilux diffs so picked them up,now i just gotta get rid of my cruiser ones.
Progress?...
Pics?
Pics?
- Spring Free
will post some pics up end of next week, progress bin alittle slow but should have front diff in place. just deciding whether or not to use extended shackles ....and another issue is i dont think il be able to get the truck outa the shed its gonna hit the door, solution put it on some smaller rims and let the air out and roll her on the rims
