Turbo muffler
Turbo muffler
im doing the exhaust for my hilux turbo and wondering should i put a full size muffler in or one of those Coby style . I want it to have a nice deep note not boy racer cackle .Any advice or input I'm sure some one has done this before .I'm doing a 2.5 inch pipe out of bends . Cheers For help
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
Re: Turbo muffler
The turbo takes quite a bit of noise out of it. Maybe build the system with no mufflers, take for a drive and see how it goes. If its way loud, get a muffler. If its not too bad, get a coby style resonator. Won't take much to add in muffler afterwards if you route the pipe with the idea of putting one in later.
My 10cents anyways.
Nath
My 10cents anyways.
Nath
- crazyclark31
Re: Turbo muffler
on my turbo safari i ran a 3in pipe right through with no mufflers of any type and it was fine. Did have a bit of a drone but didn't bother us.
Re: Turbo muffler
what hilux motor?
the L series tend to be loud as without any mufflers. a whole different ball game to the big 6 cyl's.
single 'coby' works ok tho i keep getting told it sounds like a tractor! otherwise fit two.
the other way is to fit a small coby up front and a big empty resonator at the rear (size of a main muffler but nothing in it). you can play around with a few different combo's.
Re: Turbo muffler
NO muffler. All good if you dont like it then put one in later. My muffler filled with diesel soot straight away so better off taking it out
Re: Turbo muffler
Only problem with no muffler is in NZ we need one for wof...
From virm;
From virm;
Exhaust system means a pipe assembly through which the engine exhaust gases pass to the atmosphere and includes some means of sound reduction such as a silencer or resonator
Re: Turbo muffler
Im now after a flange for a ct20 turbo to make a dump pipe .Im trying to find a full size unrestrictive muffler with straight inlet and out so i can change it without too much mod if no good
- jonossiksilvia
Re: Turbo muffler
running these in my truck. no packing in them to clog up just baffles
http://www.trademe.co.nz/motors/car-par ... 281303.htm
can see inside cutaway of muffler in this link
http://www.flowmastermufflers.com/searc ... &sc3=&sc4=
Re: Turbo muffler
thats the one ive got my eye on
Re: Turbo muffler
Those are a bit pricey. They look like the flow sound ones from Chase exhausts only painted black not silver. I've used one on each of my last two petrol cruisers. Pretty sure I only paid $80 or $90 each.
Didn't barbie drive a jeep??
Re: Turbo muffler
slide wrote:Only problem with no muffler is in NZ we need one for wof...
From virm;Exhaust system means a pipe assembly through which the engine exhaust gases pass to the atmosphere and includes some means of sound reduction such as a silencer or resonator
I put on a 3 inch straight pipe system on my hilux, 1 Kz engine,it was quiet enough to pass a vtnz Wof so I'd tend to ignore that rule as they don't care wether or not it's got a muffler long as it's quiet.
Re: Turbo muffler
ive got 2.5 of the back of the turbo with a coby on my courier td. goes thru wof no problem.
Users browsing this forum: Google [Bot] and 13 guests
