twin turboing a V6
Posted: Tue Apr 28, 2015 7:19 pm
by mudsurfv6
on a V6 ( or V8) to turbo it you would need a turbo on each side, right? problem with turbos are the lag, so the answer is twin turbo. ( big and small). right?
question is can you put a big turbo on one side and a small on the other? or would you have to quad turbo it? big and small on each side?
how would best option above ( + intercooler) compare to TRD supercharger? and $. 5VZFE. auto.
Re: twin turboing a V6
Posted: Tue Apr 28, 2015 7:33 pm
by slide
Its simple enough to run one turbo either one side with pipe around from other side, or centrally with pipes from both manifolds. Good luck mixing a big and a small turbo as twins. Very hard to keep a smooth torque curve. (hint, search Subaru valley of death). Lag is almost non-existant nowadays. Boost threshold can be a problem if you chose a large turbo, but can be minimised if you need a large turbo. Better to get one suited to what you require, and what you are wanting is the biggest factor of what to choose.
Posted: Tue Apr 28, 2015 7:48 pm
by tweake
single turbo V engine gets a boot load of lag due to the exhaust cooling down (expansion) on the long exhaust pipe from one side to the other.
there is single turbo V engines (typically diesel) where the exhaust is on the other side of the head and turbo is mounted in the V of the engine.
one turbo per bank ie one each side is much the norm.
dual turbo (as in one big and one small) your looking at sequential, which is difficult to get right, or compound which is only really needed if your chasing 40psi plus. on a V engine thats per bank so it would be quad turbo.
Posted: Tue Apr 28, 2015 8:36 pm
by mudsurfv6
just been throwing ideas around with a mate. be a while away before I get onto engine mods, too much other stuff to do first. but I'm always thinking about different ways of doing things and making a plan in my head, no doubt will change over time.
slide wrote:what you are wanting is the biggest factor of what to choose.
money is the biggest factor. not exactly sure what I'm wanting/needing yet. just good to know what can and can't be done. trying to compare against supercharger.
Posted: Tue Apr 28, 2015 8:57 pm
by Crash bandicoot
what breed of engine are you thinking of turbo charging apart from a v6/v8 obviously
Posted: Tue Apr 28, 2015 9:04 pm
by mudsurfv6
Crash bandicoot wrote:what breed of engine are you thinking of turbo charging
mudsurfv6 wrote:5VZFE. auto.
vzn185 surf.
Posted: Tue Apr 28, 2015 9:39 pm
by mudlva
Thought about throwing the 3.4 out and chucking in a 4.0 v6 out of a mid 2000s prado.
250hp and 380f/pd of toque. Just about 1/2 again inprovement from what youve got and it would fit in quite nicely
Posted: Tue Apr 28, 2015 10:05 pm
by Crash bandicoot
mudsurfv6 wrote:Crash bandicoot wrote:what breed of engine are you thinking of turbo charging
vzn185 surf.
TRD did a supercharger kit for prado eh? was for the quad cam one though.
or your really want to go turbo.?
Posted: Tue Apr 28, 2015 10:23 pm
by mudsurfv6
mudlva wrote:Thought about throwing the 3.4 out and chucking in a 4.0 v6 out of a mid 2000s prado.
haven't thought about it. done a few engine swaps and don't feel like doing another. worth thinking about though, is the mid 2000s prado front drive shaft on the left or right?
Crash bandicoot wrote:or your really want to go turbo.?
mudsurfv6 wrote:how would best option above ( + intercooler) compare to TRD supercharger?
mudsurfv6 wrote:just good to know what can and can't be done. trying to compare against supercharger.
been told twin turbo option would be cheapest but probably not as good an option as sc.
Posted: Tue Apr 28, 2015 10:45 pm
by Crash bandicoot
how hard would it be to take the lower half of the (valley cover) of the toyota v6 and mate the top half (runners) and eaton supercharger from a vy series II calias and run a 1 & 3/4 inch pulley.
just thinking outlay versus return.
just asking as that TRD one above looks suspiciously similar to the eaton that was on my VY.
Posted: Wed Apr 29, 2015 7:52 am
by The WEHI
theres a surf on trademe that comes with all the supercharger stuff for a 5vzfe not installed its had the back cut off
Posted: Wed Apr 29, 2015 7:53 am
by The WEHI
Posted: Wed Apr 29, 2015 7:57 am
by mudlva
mudsurfv6 wrote:mudlva wrote:Thought about throwing the 3.4 out and chucking in a 4.0 v6 out of a mid 2000s prado.
just had a look. Left hand side.
Posted: Thu Apr 30, 2015 10:09 pm
by mudsurfv6
The WEHI wrote:theres a surf on trademe that comes with all the supercharger stuff for a 5vzfe not installed its had the back cut off
just paid for the supercharger. so that solves that decision.
Posted: Fri May 01, 2015 7:56 am
by The WEHI
Posted: Fri May 01, 2015 5:43 pm
by mudsurfv6
problem is I just spent the $1000 I was going to use to buy some 35's so I can do the sas. now gotta save up again.
Posted: Sat May 02, 2015 4:52 pm
by coxsy
just watch a nismo gt Lm car video ,1250 hp, twin turbo front wheel drive V6
anything can be done if you got the cash,
